API: build a joint using joint origins
st00katz
st00katz
Hi, I have a component (a linkage, see attachment) with 2 joint origins. Here's what I'm trying to do: programmatically load 2 of those linkages and build a joint using the joint origins. Here's what I got so far:
	app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
	Ptr<Design> design = app->activeProduct();
	app->activeDocument()->saveAs("linkage test", app->data()->activeProject()->rootFolder(), "", "");
	auto root = design->rootComponent();
	auto project = app->data()->activeProject();
	Ptr<Occurrence> occ1, occ2;
	Ptr<DataFile> dataFile = nullptr;
	for (auto file : project->rootFolder()->dataFiles()) {
		if (file->name() == "linkage") {
			dataFile = file;
			break;
	if (!dataFile)
		ui->messageBox("file not found");
	else {
		occ1 = root->occurrences()->addByInsert(dataFile, Matrix3D::create(), false);
		occ2 = root->occurrences()->addByInsert(dataFile, Matrix3D::create(), false);
//here's something wrong: g0 and g1 are null
		auto g0 = JointGeometry::createByPoint(occ1->component()->jointOrigins()->item(0));
		auto g1 = JointGeometry::createByPoint(occ2->component()->jointOrigins()->item(1));
		auto joint = root->joints()->createInput(g0, g1);
		root->joints()->add(joint);
I would appreciate any input, hint etc on this. Pseudocode or python is ok. Thank you.
st00katz
Hi, I think I got it working:
extern "C" XI_EXPORT bool run(const char* context)
	if (!app)
		return false;
	if (!ui)
		return false;
	for (const auto &file : project->rootFolder()->dataFiles())
			dataFile = file;
			break;
	if (app->activeDocument()->name() == "Untitled")
	for (const auto &occ : root->allOccurrences())
		occ->deleteMe();
	if (!dataFile)
	else {
		auto x = occ1->component()->sketches()->item(0)->sketchCurves()->sketchCircles()->item(0);
		auto y = occ2->component()->sketches()->item(0)->sketchCurves()->sketchCircles()->item(0);
		auto g1 = JointGeometry::createByCurve(x, JointKeyPointTypes::CenterKeyPoint);
		auto g2 = JointGeometry::createByCurve(y, JointKeyPointTypes::CenterKeyPoint);
		auto joint = root->joints()->createInput(g1, g2);
		joint->geometryOrOriginOne(occ1->component()->allOccurrences()->item(0)->component()->jointOrigins()->item(0));
		joint->geometryOrOriginTwo(occ2->component()->allOccurrences()->item(0)->component()->jointOrigins()->item(0));
		joint->setAsRevoluteJointMotion(JointDirections::ZAxisJointDirection);
	return true;
Thoughts?
Also, why I'm seeing this site in Chinese?
