API access to NCPrograms
dames123
dames123
Is there a way to insure this toggle is off using the API?
Thanks.
boopathi.sivakumar
Hi @dames123
You can do like this
ncProgram.parameters.itemByName('nc_program_orderByTool').value.value = False
Boopathi Sivakumar
Principal Technology Consultant
dames123
Thank you @boopathi.sivakumar .
What's the difference between ncParameters and ncProgram.parameters? I can't find it in the help file. My script uses ncParameters.
example:
for setup in setups:
            ncIpt: adsk.cam.NCProgramInput = ncPrograms.createInput()
            ncIpt.displayName = setup.name
            ncParameters = ncIpt.parameters
            # Set the filename to the same as the setup parameter
            ncParameters.itemByName('nc_program_filename').value.value = setup.parameters.itemByName('job_programName').value.value
            ncParameters.itemByName('nc_program_openInEditor').value.value = False
            ncParameters.itemByName('nc_program_useMachineConfig').value.value = True
            ncParameters.itemByName('nc_program_comment').value.value = setup.parameters.itemByName('job_programComment').value.value
            #ncProgram.parameters.itemByName('nc_program_orderByTool').value.value = False
boopathi.sivakumar
Ah! my case the variable name was ncProgram but in your case it should be like
ncParameters.itemByName('nc_program_orderByTool').value.value = False
Boopathi Sivakumar
dames123
I tried that and it didn't seem to work at first but I figured it out.
Thanks @boopathi.sivakumar
