additionalEntities on selection
Hi all,
I have tested and found that it is not possible to use additionalEntities property on select event. Instead, it is only applicable to preSelect event.
In the simple code below, the additionalEntities property is used to add additional faces which are neighboring to the selected face. However, this only works in preSelect handler, but not in select handler.
In my use case, the computations involved are rather large, therefore when the users hover through the faces, they will experience severe lagging issues because of the preSelect handler. I would like to move the calculations for additional entities to select event to improve the smoothness of users' operations.
In short, I want the API to only compute for additional entities AFTER a selection has been made, instead of hovering. If the API is unable to do this, is there any workaround to achieve this objective?
Thank you for your time to read this. If you are interested, this code below is for demonstration: Additional entities work as expected in preSelect handler but not in select handler.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
class mySelectionCommand_commandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
try:
command = adsk.core.CommandCreatedEventArgs.cast(args).command
commandInputs = command.commandInputs
selectionInput1 = commandInputs.addSelectionInput('mySelectionInput1',
'MySelection1',
'Select any face')
selectionInput1.addSelectionFilter('Faces')
selectionInput1.setSelectionLimits(0)
#Event handlers
# mySelectionCommand_ps = mySelectionCommandInput_preSelectEventHandler()
# command.preSelect.add(mySelectionCommand_ps)
# _handlers.append(mySelectionCommand_ps)
mySelectionCommand_s = mySelectionCommandInput_selectEventHandler()
command.select.add(mySelectionCommand_s)
_handlers.append(mySelectionCommand_s)
except:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# class mySelectionCommandInput_preSelectEventHandler(adsk.core.SelectionEventHandler):
# def __init__(self):
# super().__init__()
# def notify(self, args):
# try:
# eventArgs = adsk.core.SelectionEventArgs.cast(args)
# selected_face = adsk.fusion.BRepFace.cast(eventArgs.selection.entity)
# neighbour_faces = adsk.core.ObjectCollection.create()
# for e in selected_face.edges:
# for f in e.faces:
# if f is not selected_face:
# neighbour_faces.add(f)
# eventArgs.additionalEntities = neighbour_faces
# except:
# _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class mySelectionCommandInput_selectEventHandler(adsk.core.SelectionEventHandler):
def __init__(self):
super().__init__()
try:
for f in e.faces:
except:
_app: adsk.core.Application = adsk.core.Application.get()
_ui: adsk.core.UserInterface = _app.userInterface
_handlers = []
def run(context):
try:
mySelectionCommand = _ui.commandDefinitions.itemById('mySelectionCommand')
if mySelectionCommand:
mySelectionCommand.deleteMe()
mySelectionCommand = _ui.commandDefinitions.addButtonDefinition(
'mySelectionCommand',
'MySelection',
'Select a random face',
'./MySelection')
mySelectionCommand_cc = mySelectionCommand_commandCreatedEventHandler()
mySelectionCommand.commandCreated.add(mySelectionCommand_cc)
_handlers.append(mySelectionCommand_cc)
addin_tab = _ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
mySelectionControl = addin_tab.controls.itemById('mySelectionCommand')
if mySelectionControl: mySelectionControl.deleteMe()
mySelectionControl = addin_tab.controls.addCommand(mySelectionCommand)
mySelectionControl.isVisible = True; mySelectionControl.isPromoted = True
mySelectionCommand.execute()
except:
(To run the code above you need a resource folder named 'MySelection'. Or, change it as you wish)
