Adding empty space after control on form.
ebunn3
ebunn3
Is there a way to enter empty space or a line break between controls on a form.
Eric
j.han97
Maybe adding an empty commandInput (e.g., TextBoxCommandInput) will work. What is the reason of this empty line? In my case the main reason of inserting a line break is for "grouping" therefore I separated them using GroupCommandInput or even TabCommandInput.
Hope it helps.
ebunn3
Thanks.  I’ll try the empty text box command.  My main goal is simply visual at this point.  The controls are already in a group.  I never tried groups within groups if that might work as well.
Eric
ebunn3
j.han97,
The TextBoxCommandInput suggestion will work for me to put in an empty line as needed. Thanks for the great suggestion.
Eric
BrianEkins
I did something similar using an image command input. In my case, rather than leave it empty, I had a line in the image to better define a divider.
Brian Ekins
