Addin's disconnect and cannot be opened.
I find myself really frustrated.
- I make an addon folder and work on the addon. I can set it to load on startup etc, and as long as I do not close fusion, it works fine.
- ...but often when i Start fusion the addon is not loaded, despite exit was clean and it was set to load on startup.
- When i try to open the folder from fusion I get this error when i try to open the folder where the addin was previously loaded from:
I know for a fact the addon works, because i can rename the original folder, then recreate addon in Fusion and then move and overwrite the files in the new addon folder with the files from the old. - Then reload the addon and keep working on it..
- And yes, names are identical both in the json/manifest, foldername,py-name,etc. So this error is incorrect in stating files do not exist.
- Then I log out and into fusion, and sometimes face the same problem again and have to rename and copy the folder.
