Add Rectangular Pattern Feature to Component
ebunn3
ebunn3
I've pasted a code example below that creates a Rectangular Pattern Feature and adds it to a new document.  I want to re-configure this so it adds the pattern feature to a new component within an active file instead of creating a new file and adding it to that one.  Can someone help me re-configure this example to do this?
I've tried to change by passing in a new component and using it as my root component and get the following error:
Traceback (most recent call last): File "C:/Users/ebunn/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Nesting_True_Type_By_Points_Comp/Nesting_True_Type_By_Points_Comp.py", line 736, in <module> PatternBodies(preN[1],newComp,numX,moveX,numY,moveY) File "C:/Users/ebunn/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Nesting_True_Type_By_Points_Comp/Nesting_True_Type_By_Points_Comp.py", line 683, in PatternBodies rectangularFeature = rectangularPatterns.add(rectangularPatternInput) File "C:\Users/ebunn/AppData/Local/Autodesk/webdeploy/production/8814bf1cdd9624465cbdf7f023becc629a5ffbe5/...", line 28366, in add return _fusion.RectangularPatternFeatures_add(self, input) RuntimeError: 2 : InternalValidationError : Utils::getObjectPath(obj.get(),objPath, nullptr,path)
Here is an example of the attempted change.  The new component I am trying to add it to is called newComp.  I am pulling the bodies from another component passed in as comp:
def PatternBodies(comp,newComp,quantityOne,distanceOne,quantityTwo,distanceTwo😞
    app = adsk.core.Application.get()
    ui = app.userInterface
    # Create a document.
    # doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    # # Get the root component of the active design.
    rootComp = newComp#design.rootComponent
    #Get  the document units (bookmark:units)
    units = design.unitsManager.defaultLengthUnits
    # Create input entities for rectangular pattern
    inputEntites = adsk.core.ObjectCollection.create()
    for i in comp.bRepBodies:
        inputEntites.add(i)
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        rootComp = design.rootComponent
        # Create sketch
        sketches = rootComp.sketches
        sketch = sketches.add(rootComp.xZConstructionPlane)
        sketchCircles = sketch.sketchCurves.sketchCircles
        centerPoint = adsk.core.Point3D.create(0, 0, 0)
        sketchCircles.addByCenterRadius(centerPoint, 3.0)
        # Get the profile defined by the circle.
        prof = sketch.profiles.item(0)
        # Create an extrusion input
        extrudes = rootComp.features.extrudeFeatures
        extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        # Define that the extent is a distance extent of 5 cm.
        distance = adsk.core.ValueInput.createByReal(5)
        extInput.setDistanceExtent(False, distance)
        # Create the extrusion.
        ext = extrudes.add(extInput)
        # Get the body created by extrusion
        body = ext.bodies.item(0)
        inputEntites.add(body)
        # Get x and y axes for rectangular pattern
        xAxis = rootComp.xConstructionAxis
        yAxis = rootComp.yConstructionAxis
        # Quantity and distance
        quantityOne = adsk.core.ValueInput.createByString('3')
        distanceOne = adsk.core.ValueInput.createByString('8 cm')
        quantityTwo = adsk.core.ValueInput.createByString('3')
        distanceTwo = adsk.core.ValueInput.createByString('8 cm')
        # Create the input for rectangular pattern
        rectangularPatterns = rootComp.features.rectangularPatternFeatures
        rectangularPatternInput = rectangularPatterns.createInput(inputEntites, xAxis, quantityOne, distanceOne, adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
        # Set the data for second direction
        rectangularPatternInput.setDirectionTwo(yAxis, quantityTwo, distanceTwo)
        # Create the rectangular pattern
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Appreciate the help.
Eric
Jorge_Jaramillo
Hi @ebunn3 ,
Please find attached a script for it.
Just to clarify: the bodies created in the rectangular pattern are kept in the source component, so at the end of the function it moves them to the new created component.
def PatternBodies(  srcComp: adsk.fusion.Component,
                    destOccu: adsk.fusion.Occurrence,
                    quantityOne: adsk.core.ValueInput,
                    distanceOne: adsk.core.ValueInput,
                    quantityTwo: adsk.core.ValueInput,
                    distanceTwo: adsk.core.ValueInput):
    try:
        for i in srcComp.bRepBodies:
            inputEntites.add(i)
        xAxis = srcComp.xConstructionAxis
        yAxis = srcComp.yConstructionAxis
        rectangularPatterns = srcComp.features.rectangularPatternFeatures
        # move the bodies to the destComp, since the new bodies are created in the same component they belongs
        bodyArray = [body for body in rectangularFeature.bodies]
        # I had to create this body array, because iterating over rectangularFeature.bodies gives an error on item #8.
        for body in bodyArray:
            body.moveToComponent(destOccu)
    except:
        app.log(f'Error in PatternBodies: {traceback.format_exc()}')
def rectangularPattern():
    try:
        #source component to take bodies from
        rootComp = adsk.fusion.Design.cast(app.activeProduct).rootComponent
        srcComp = rootComp
        #create the new component
        matrix = adsk.core.Matrix3D.create()
        destOccu = rootComp.occurrences.addNewComponent(matrix)
        destComp = destOccu.component
        destComp.name = 'newComponent'
        # create ValueInput's for each dimension
        PatternBodies(srcComp, destOccu, quantityOne, distanceOne, quantityTwo, distanceTwo)
    except:
        app.log(f'Error in rectangularPattern: {traceback.format_exc()}')
Hope this help to solve your problem.
Jorge
ebunn3
Walter,
See screenshot below.  I want to use the bodies in Component 1:1 and create a new component that will contain the rectangular pattern.
Thanks for all of the help.
Eric
Jorge_Jaramillo
Give a try at this script which worked for me.
If you have two bodies on source component, you will get 18 (= 2 x 3 x 3) in the new component.
    try:
            # copy bodies to dest component
            cpb = destOccu.component.features.copyPasteBodies.add(i)
            inputEntites.add(cpb.bodies[0])
        xAxis = destOccu.component.xConstructionAxis
        yAxis = destOccu.component.yConstructionAxis
        rectangularPatterns = destOccu.component.features.rectangularPatternFeatures
    except:
    try:
        srcComp = rootComp.occurrences.item(0).component  # <---- bodies from first component under root component; change according to your design
    except:
The change I made is to copy source bodies to new component before making the rect pattern, instead of moving the result bodies at the end.
Jorge
ebunn3
Thank you so much!!!  Perfect.
Eric
ebunn3
I've made a few changes to the script allowing a component selection first.  Just wanted to post the final script for anyone else's benefit.  Thanks again to @Jorge_Jaramillo for the great solution.
def rectangularPattern(srcComp,quantity1,distance1,quantity2,distance2):
    def traverseForBodies(occs,lst):
        """gets all bodies in occurence, including bodies in childOccurences
        lst = list()
        traverseForBodies(product,lst)"""
        if not occs.bRepBodies.count == 0:
            for bod in occs.bRepBodies:
                if bod.isVisible:lst.append(bod)
        #check child occurences
        if occs.childOccurrences:
            occChild = occs.childOccurrences
            for child in occChild:
                traverseForBodies(child,lst)
        try:
            lst = list()
            traverseForBodies(srcComp,lst)
            for i in lst:
        except:
    try:
        destComp.name = 'Main_Rect_Pattern'
        # create ValueInput's for each dimension quantity1,distance1,quantity2,distance2
        quantityOne = adsk.core.ValueInput.createByString(quantity1)
        distanceOne = adsk.core.ValueInput.createByString(distance1 + ' cm')
        quantityTwo = adsk.core.ValueInput.createByString(quantity2)
        distanceTwo = adsk.core.ValueInput.createByString(distance2 + ' cm')
    except:
#Select body
comp = ui.selectEntity('Select a component', 'Occurrences').entity#.component
print("")
bbMin=comp.boundingBox.minPoint
bbMax=comp.boundingBox.maxPoint
prodL = bbMax.x-bbMin.x
prodW = bbMax.y-bbMin.y
quantityOne=str(4)
distanceOne=str(prodL)
quantityTwo=str(4)
distanceTwo=str(prodW)
rectangularPattern(comp,quantityOne,distanceOne,quantityTwo,distanceTwo)
Eric
