Add menu item to Flat pattern modify panel?
thomasa88
thomasa88
Is there any way to add a command to the flat pattern modify panel?
I have looked at UI interface dumps and I cannot seem to find the panel.
This seems to be a related problem: https://forums.autodesk.com/t5/fusion-api-and-scripts-forum/add-in-not-shown-in-quot-flat-pattern-qu...
BrianEkins
Something is weird here, but I think I found a solution for your specific issue. I believe the following code will return the "FLAT PATTERN SOLID" tab, where you'll find the expected tabs and should be able to add your commands.
flatTab = ui.allToolbarTabs.itemById('FlatPatternSolidTab')
The weird thing is that I can't figure out which workspace that tab belongs to. It doesn't really matter because we can access it directly instead of going through the workspace, but it's not working like I expected.
Brian Ekins
thomasa88
That works, thank you!
I ended up with these two lines:
ui.allToolbarTabs.itemById('FlatPatternSolidTab').toolbarPanels.itemById('SolidModifyPanel')
ui.allToolbarTabs.itemById('FlatPatternSurfaceTab').toolbarPanels.itemById('SurfaceModifyPanel')
