Activating a referenced component product
SaeedHamza
Advisor Advisor
SaeedHamza
Hello everyone,
I'm trying to activate the product that contains a referenced component. This is what I want to do :
I want to select a referenced component (linked) from a design that it was imported into, and open the original design of that component.
What I want to achieve here is simply make the original design (product) of that referenced component the current active product in the app, so that I can edit with a single script both files, the original design of the referenced component and the one it was imported into.
I made a lot of research regarding this, but I just can't seem to change the active product to be the referenced component original file, because I want to script to go back and forth between both designs while running.
I have no issue if I have to at least manually open the original design of the referenced component, but I need to change the active product as mentioned above back and forth between both products.
Any help would be much appreciated!
Thanks.
Saeed Hamza
kandennti
Hi @SaeedHamza .
The attached f3z file looks like this.
The following script will open the external component and create a new occurrence in the root component of both documents.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        # active document
        parentDoc: fusion.FusionDocument = app.activeDocument
        # Get document for the first external component
        childDoc: fusion.FusionDocument = get_external_component_document()
        if not childDoc:
            return
        # This method is slow
        # app.documents.open(childDoc.dataFile)
        # Since it is already loaded, simply activate it and it will appear
        childDoc.activate()
        # Create a new occurrence in the root component of each document
        create_internal_component(parentDoc)
        create_internal_component(childDoc)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_internal_component(
doc: fusion.FusionDocument) -> None:
    doc.activate()
    doc.design.rootComponent.occurrences.addNewComponent(
        core.Matrix3D.create()
def get_external_component_document(
) -> fusion.FusionDocument:
    des: fusion.Design = app.activeProduct
    root: fusion.Component = des.rootComponent
    occ: fusion.Occurrence = None
    for occ in root.occurrences:
        if occ.isReferencedComponent:
            return occ.documentReference.referencedDocument
    return None
