Accessing Arrays
Accessing Arrays
simon.dyer
Accessing Arrays
simon.dyer
I am tweaking a JS script and need to access an array, but it keeps failing.
Here is a code snippet:
var points = new Array(50);
points[prf] = adsk.core.ObjectCollection.create();
var point = adsk.core.Point3D.create(data[i][0], data[i][1], data[i][2]);
points[prf].add(point);
Now I want to get the value of Z from a point in that array.
Ive tried
var z=points[1].z;
  z=points[i][2];
then assuming its a method:
z=points[i].getData(x,y,z);
Nothing seems to work for me.
marshaltu
I would like to tell you Javascript API has been moved to maintenance mode. Please read Brian's post as below:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/new-functionality-and-javascript-moves-to-...
Regarding to your specific issue, the following sample will demo how to access ObjectCollection.
//Author-
//Description-
function run(context) {
    "use strict";
    if (adsk.debug === true) {
        /*jslint debug: true*/
        debugger;
        /*jslint debug: false*/
    var ui;
    try {
        var app = adsk.core.Application.get();
        ui = app.userInterface;
        var points = [];
        points[0] = adsk.core.ObjectCollection.create();
        points[0].add(adsk.core.Point3D.create(0, 0 ,0));
        var z = points[0].item(0).z;
        ui.messageBox("Z: " + z.toString());
    catch (e) {
        if (ui) {
            ui.messageBox('Failed : ' + (e.description ? e.description : e));
    adsk.terminate();
Marshal
Marshal Tu
Fusion Developer
