Accessing adsk and sub libraries from command line
scott.nortman
scott.nortman
How can I get access to the Fusion adsk libraries when I have a Python terminal open from a command prompt?
Ie, when I call
>>> import adsk.core
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'adsk'
jiri.manak
are you sure you run the python which comes with the Fusion 360 environment?
I am running PyCharm with Fusion 360 plugin. If set up correctly it opens python console where importing adsk is not a problem.
Jiri
scott.nortman
Yes, I am running the python.exe from the Fusion 360 install folder.
I previously did have other installations of Python that I removed via "add / remove programs" ; perhaps my site-packages is set up wrong?
jiri.manak
sorry may be stupid questions:
... are sure that you took the last one?
... are aware the installation folder changes at every update/deployment?
try this at your python console
>import sys
>sys.executable
... this shows you which python.exe are you using
if you have windows PC (I can't help with Mac)
the adsk are in
your_deployment_folder\\Api\\Python\\packages\\adsk\...
python.exe is in
your_deployment_folder\\Python
depolyment folders name is logn alphanumeric string
