Access name of Manufacturing Model that a setup is using
BenHarper-3Dtek
BenHarper-3Dtek
I am attempting to find the name of the Manufacturing model that a setup is linked to.
When making a setup manually through the Manufacturing environment, there is a drop-down in the setup creation modal window to select from the available manufacturing models.  However, I cannot find where this data is stored in the setup object in the API.
You can access the model data that is selected immediately below this drop-down through setup.models.
Though these are of different types depending on what is selected and  I can't seem to climb back up the tree from one of these objects to see the name of the manufacturing model they live in.
Can anyone tell me how to find the manufacturing model object/name from a given setup in the API?
jeff.pek
Hi -
The dropdown in the setup dialog is associated with a parameter named "job_workingModel". So, you can access the name (internal name) of the manufacturing model by accessing the value of that parameter.
Hope this helps,
  jeff
BenHarper-3Dtek
Jeff, Many thanks.
I cannot find this parameter anywhere on google, intellisense or looking over objects when debugging - so no idea how you came across it!
But glad you did, any chance you can elaborate on how you put your hands on that value through the python API?
Cheers
jeff.pek
You should be able to follow the examples that get the value of any arbitrary parameter via the API. This would be through the "Value" property of the parameter. Something like (from memory): setup.parameters.itemByName("job_workingModel").value.value.
I have "internal access", so was able to look up the value. For this one, it's hard to deduce what the parameter would be, since a proxy parameter, "job_workingModel_select" is what is shown in the UI, so when you hover over the dropdown, that's what you see there. It's possible, that that parameter could provide the value as well.
Jeff
Jeff
BrianEkins
It can be tricky to determine the parameter you want to access. I think you'll find this useful. An add-in delivered with Fusion dumps a list of all the parameters associated with a setup, operation, or tool. To enable the add-in, run the "Scripts and Add-Ins" command, choose the "Add-Ins" tab, and scroll to the bottom of the list. Select "CAM_API_Utilities", check the "Run on Startup" check box so it will automatically be loaded the next time you run Fusion, and click the "Run" button.
Now, you should see two new commands in the INSPECT panel. Running the "Export Parameters" command will let you choose a Setup, Operation, or Tool, and then it will dump out all the associated parameters into a text file.
Brian Ekins
BenHarper-3Dtek
Many thanks @BrianEkins & @jeff.pek for your help.
I can access and read the manufacturing model param values now - though not write to them.
I always get "Invalid enumeration value."   Looking into getChoices(), shows that only default is an acceptable option. This is confirmed by looking a the output from export parameters:
title: Manufacturing Model
expression: "'MfgWorkingModel'"
isEditable: True
isEnabled: True
ChoiceParameterValue
value: MfgWorkingModel
choices:
name: <Default>, value: 'default'
I currently have 3 manufacturing models, why is it that the choiceparameter choices are not updated to include the other manufacturing models as valid choices.  Of course I can successfully select them in the setup dialog in fusion, but cannot set them via the API as its not in the list of acceptable values.
I have tried to set it with
setup.parameters.itemByName("job_workingModel").ChoiceParameterValue = "\'default\'"
setup.parameters.itemByName("job_workingModel").ChoiceParameterValue = "\'MfgWorkingModel\'"
These do not error out but also do not take effect.
mmparam = setup.parameters.itemByName('job_workingModel')
choiceVal: adsk.cam.ChoiceParameterValue = mmparam.value
choices = choiceVal.getChoices()
choiceVal.value = "default" #THIS WORKS
choiceVal.value = "MfgWorkingModel" #Invalid enumeration value
choiceVal.value = "/'MfgWorkingModel/'" #Invalid enumeration value​
Yet other similar items with set/known values like
jobparam = setup.parameters.itemByName('job_type')
choiceVal: adsk.cam.ChoiceParameterValue = jobparam.value
choiceVal.value = "milling"
do not have an issue.
Any ideas how I can get it to accept a manufacturing model that exists but isn't on the list?
rolandas_vegis
Hi, I encountered the same issue. Did you find a way to achieve this?
