Topluluk
Merhabalar ,
Bu yazımızda , Autodesk Fusion 360 programında aktif olarak kullanılan klayve kısayollarından bağsedeceğiz.
Command | Key Combinations |
Extrude | E |
Hole | H |
Press Pull | Q |
Fillet | F |
Move | M |
Toggle Visibility | V |
Toggle Component Color Cycling | Shift + N |
Model Toolbox | S |
Appearance | A |
Compute All | Crtl + B (Windows) or Command + B (Mac) |
Joint | J |
As-built Joint | Shift + J |
Line | L |
2-point Rectangle | R |
Center Diameter Circle | C |
Trim | T |
Offset | O |
Measure | I |
Project | P |
Normal / Construction | X |
Sketch Dimension | D |
Scripts and Add-ins | Shift + S |
Window Selection | 1 |
Freeform Selection | 2 |
Paint Selection | 3 |
Delete | Del |
System Keyboard Shortcuts | Windows Key Combinations | Mac Key Combinations |
Create Version | Ctrl + S | Command + S |
Recovery Save | Ctrl + Shift + S | Command + Shift + S |
Canvas Selection | Windows Key Combinations | Mac Key Combinations |
Pan | Hold Middle Mouse Button | Hold Middle Mouse Button |
Zoom | Roll Middle Mouse Button | Roll Middle Mouse Button |
Orbit | Hold Shift + Hold Middle Mouse Button | Hold Shift + Hold Middle Mouse Button |
Orbit around point | Hold Shift + Click then Hold Middle Mouse Button | Hold Shift + Click then Hold Middle Mouse Button |
Undo | Ctrl + Z | Command + Z |
Redo | Ctrl + Y | Command + Y |
Copy | Ctrl + C | Command + C |
Paste | Ctrl + V | Command + V |
Cut | Ctrl + X | Command + X |
Sculpt Workspace Selection | Windows Key Combinations | Mac Key Combinations |
Grow selection | Shift + Up Arrow | Shift + Up Arrow |
Shrink selection | Shift + Down Arrow | Shift + Down Arrow |
Loop selection | Alt + P | Control + P |
Loop grow selection | Alt + O | Control + O |
Ring selection | Alt + L | Control + L |
Ring grow selection | Alt + K | Control + K |
Ring shrink selection | Alt + J | Control + J |
Previous U | Alt + Left Arrow | Control + Command + Left Arrow |
Next U | Alt + Right Arrow | Control + Command + Right Arrow |
Previous V | Alt + Down Arrow | Control + Command + Down Arrow |
Next V | Alt + Up Arrow | Control + Command + Up Arrow |
Range selection | Alt + M | Command + M |
Invert selection | Alt + N | Command + N |
Toggle box mode | Ctrl + 1 | Control + 1 |
Toggle control frame mode | Ctrl + 2 | Control + 2 |
Toggle smooth mode | Ctrl + 3 | Control + 3 |
Select edge ring | Double-click an edge | Double-click an edge |
Select face ring | Select two faces then double-click a third face | Select two faces then double-click a third face |
Edit Form Command | Windows Key Combinations | Mac Key Combinations |
Add geometry | Alt + Drag | Alt + Drag |
Add geometry and keep creases | Alt + Ctrl + Drag | Alt + Command + Drag |
Render Workspace Command | Windows Key Combinations | Mac Key Combinations |
Appearance | A | A |
Animate Workspace Command | Windows Key Combinations | Mac Key Combinations |
Transform Components | M | M |
Auto Explode All Levels | U | U |
Manual Explode | E | E |
View | U | U |
Publish Video | P | P |
Simulate Workspace Command | Windows Key Combinations | Mac Key Combinations |
New Simulation Study | N | N |
Structural Constraint | C | C |
Structural Loads | L | L |
Force | F | F |
Model View | Ctrl + L | Command + L |
DOF View | Ctrl + D | Command + D |
Groups View | Ctrl + G | Command + G |
Results View | Ctrl + R | Command + R |
Settings | E | E |
CAM Workspace Command | Windows Key Combinations | Mac Key Combinations |
Generate Toolpath | Ctrl + G | Command + G |
Duplicate | Ctrl + D | Command + D |
Show Log | Ctrl + L | Command + L |
Scripts and Add-Ins | Shift + S | Shift + S |
Drawing Workspace Command | Windows Key Combinations | Mac Key Combinations |
Projected View | P | P |
Move | M | M |
Delete | Delete | Delete |
Center Mark | C | C |
Dimension | D | D |
Text | T | T |
Balloon | B |
B |
Saygılarımla,
Hasan ER
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
