#URGENT# Since Aug Update Opening Existing Models Crashes F360
Kmetiuk
Kmetiuk
Since the August update that I did yesterday, when I open certain models it crashes Fusion 360. I have updated all drivers, restarted multiple times and still crashes. It is 2 specific models that crash the program.
It gets hung up on "computing base mesh feature1" then down it goes. I pasted a snip of the feature that fails.
I can open a couple other models, just not this one. Please advise.
Kmetiuk
@RajkumarIlanchelian
I saw you post about a crash issue with base compute, I am having a similar issue but I think it is related to a mesh.
Please see above pic.
I can DM you the model if it helps.
Kmetiuk
@Rajkumar.ilanchelian
Here is the error report 310768347
RajkumarIlanchelian
@Kmetiuk Thank you for the error ID. I can confirm it is the same issue that we are chasing internally to fix ASAP. We are hoping to get an update to resolve this issue in about 6-8 hours from the time of this posting.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
Please update to 2.0.10811. This should contain the fix for the crash.
Autodesk Fusion
Join Fusion Insider
Kmetiuk
I am still stuck on 2.0.10806.  I have restarted multiple times, wont seem to update. Maybe its not rolled out yet?
RajkumarIlanchelian
)@Kmetiuk If you are on windows, please re-install Fusion (you don't have to uninstall). We are working to fix the live update which means when we deploy 2.0.1081x we will ask you to re-install again (no need to uninstall). Sorry for the inconvenience.
Autodesk Fusion
Join Fusion Insider
