- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have encountered this problem to varying degrees since I started using fusion, but today the problem is bad enough that I have decided to actually see if there is anything that can be done about it. I'm not sure if it's a software problem, or a problem with computer on which I have Fusion installed, so any advice would be appreciated.
When I draw sketches; I only recall this happening whilst using the 'line' tool, I will click on the point from which I wish a line to extend, but an extra line is added prior to the line that has been drawn to the dimension required, meaning that the line will be longer than necessary. The extra line occurs as I click the point of origin then move the cursor in the direction in which the line is to extend, and it is often quite short and easy to go unnoticed until a significant amount of sketching has been done, only to realise that the addition of this line has caused the geometry to be totally incorrect. On other, less frequent occasion, the same thing has occured, but instead of a line being drawn, an arc is drawn. I understand this is an integrated feature of the 'line' tool, and I am aware of how to use this function, but on the occasions where this has happened, the cursor was not moved in such a way.
Does this happen to any one else? My computer isn't exactly new, and the hardware limitations aren't much beyond the minimum requirements for the Fusion system, so I could understand if there wasn't much that could be done, but I'm fairly certain the system was updated at the end of last week, and the increased occurrence of this issue seems to correspond with that update, so I thought I would ask on here and see if it had anything to do with software bugs.
Thanks for your time if you read this.
