unable to extrude svg sketch through geometry lines part of a single body
timlees2000
timlees2000
Hi all I am sure there is a better way to explain my issue,
I am trying to add a texture to several bodies I created in fusion 360, I will try to include images,  I can extrude from object using my sketch only if the part of the sketch is not going over a geometry line that makes up the body. the only way I have found to be able to do this is to edit the sketch and add in lines ofset from the geomerty lines, but the overall finish is lines in the body, does nay one have any advice how I can remove the lines or work around this,
I also can not select more than one surface of my body, if anyone can work this out it may fix my issues.
thanks Tim
I have a screencast but it is still pending I will upload the link later
Replies (8)
ryan.bales
Autodesk Support
Autodesk Support
Hi @timlees2000,
I responded to your other thread about the same looking objects with a dxf and the answer is really the same. We can't know how to do it without seeing it. Geometry of this nature is very specific and unique to your design.
Most often a dxf or svg can't extrude because its not closed or its got far to many edges/faces and fusion won't compute it. We definitely need to see the screencast and the design.
Ryan Bales
Fusion 360 Product Support
timlees2000
Thanks yes I am still struggling with this I have added the screen cast now
timlees2000
Sorry the screencast is still pending, as soon as it is available I can upload it
regards
Tim
timlees2000
finally the screencast is ready to share so here is what I am trying to do
timlees2000
morning Ryan, my screencast is now ready so I have uploaded it, I hope this show what I am trying to do and the issues I am having, there may be an answer or way to achieve the same result, Thanks Tim
ryan.bales
Autodesk Support
Autodesk Support
It's possible the from object extrusion is not working because its picking a face and not the entire body. Extrusion is a very planer command and the from object is picking a non planer face.
There are likely a number of workaround to what you are doing but its still going to be best if we can see the model and play with it.
Ryan Bales
timlees2000
OK how would you like to get the model files and image file I have included images of a test print I did of the basic shape but this was a complete extrude right through the bodies and then cut back by 0.2mm using an ofset from the body, the problem with this is they are all bodies and cleaning out the extra parts is a pain due to the tecnical body internal bits.
ryan.bales
Autodesk Support
Autodesk Support
You can share a public link via the data panel and send it in a reply here or a private message.
Ryan Bales
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
