Message 1 of 18
06:09 AM
I have a set of splines imported from a CSV file that I would like to make a surface (and then a solid).
At one "end" of the object the splines begin to overlap in the middle, which I suspect causes the trouble.
I keep getting this error:
Warning: The loft could not be created.
Try changing the inputs, swapping profiles for rails or a centerline, or adjusting the continuity conditions.
Have a look here: https://a360.co/2rX8m3f
How can I make a surface from the visible splines, and then afterwards make it a solid?
