Greetings
I have a .dwg file from a customer (Geometrien elementet.dwg, attached).
It is generated in AutoCAD (using hsbcad) and exported as .dwg. It consists of 3 layers.
View in AutoCAD:
I can also view it online at sharecad.org:
But when it open it in Fusion, there are four elements, but they are all empty:
I also have the file as .dxf (Geometrien element.dxf, attached), but Fusion cannot/will not import it.
It is critical that the file is accessible via Fusion. What can I do to open it correctly?
Best regards,
Christian
