Announcements
Sketch not aligning in two axises
g.isley
g.isley
When I draw a circle on the top plane.  Now if I rotate the view 90 degrees the drawing is not centered on the 90 degree axis.  My model will not be square on the vertical and horizontal axis.  Why is this?
See below.
Screen Shot 2020-09-19 at 12.00.58 PM.pngScreen Shot 2020-09-19 at 12.00.12 PM.png
jhackney1972
You most likely have 3D Sketch activated and you have sketch the circle in an offset plane. If so, just uncheck the entry in the Sketch Palette.
John Hackney, Retired
g.isley
You are right. When I started a new sketch that worked fine. However on my existing drawing it did not change the slant.
jhackney1972
If a sketch is already created, with the 3D Sketch option on, then taking if off does not affect the historical sketch.  You will  have to edit it manually, in this case just redraw it will be easiest.
