Revolute joints randomly freeze up
Noah_Katz
Noah_Katz
I have a machine design with many revolute joints that sometimes work and sometimes don't.
Sometimes exiting and reopening the design frees it up.
One time I got it to work by grounding one of the components, which is itself attached to a grounded component, but that won't always be possible without violating the design intent.
Sometimes if I redefine the joint limits to a position that it's not currently in it will force it to move and free it up.
Right now that's not working and I'm pretty fed up with the whole situation as it's frequent and time-consuming (for recalculation).
Are there some guidelines I should know about?
Link to model: https://a360.co/2r2hlvZ
Right now I'm wanting to pivot the red roller down but I can't.
Replies (15)
@Noah_Katz
Hint: for a stable model it is a good idea to avoid warnings and errors.
I did a "Compute All" and got this:
Especially warnings for joints are not helpful for clean kinematic calculations.
Example:
Noah_Katz
Easier said than done 🙂
I'll try deleting and recreating them first, as it could take many hours going through and fixing them all.
I know it's not good practice, but this is a one-time design that I'm almost finished with and I want to get to making parts.
Would it be correct to assume that rigid joints between components other than the ones with troublesome revolute joints are unlikely to be part of the problem?
Thanks, @Anonymous
@Noah_Katz
Just my personal opinions:
1) Don´t ignore warnings, do something immediately to correct the model/sketch. If you ignore them, it´s getting worse and worse.
2) If you apply a workflow assembling parts with joints only, there should be no reason for any "capture position" oder "move" operations left in the timeline. I might capture a position to create a joint - but after joint creation my next step is to delete the  "capture position".
3) rigid-joints part of the problem? Maybe. I suspect that the Fusion solver algorithms don´t like rigid joints with missing joint-origins for both components.
for example:
Noah_Katz
I now (I started the design with much less experience) try to delete Capture Position operations, but sometimes that causes a lot of other features to turn yellow or red.
Rather than spend hours trying, and perhaps failing,  to fix them all, I leave the Capture Position.
Speaking of Capture Position, do you know why it pops up when I edit sketches?
It's annoying to have to chase the sketch all over the screen if I say Continue.
Good point about those rigid joints, I'll investigate.
What drives me crazy is that the joints seem to go bad without provocation, like when I edit a sketch of an unrelated component.
Noah_Katz
Hmm, perhaps deleting the Capture Positions causes problems because the joints are bad...
Sorry, obviously I used the wrong wording regarding "capture position" - causing a misunderstanding (English is not my native language).
My intention was not to suggest that you should delete them in your specific example. It requires a workflow where you position all the components with joints in a "clean" (proper?) way. That was meant as a hint for a future project - not for the current one.
Sorry again.
Noah_Katz
No problem.
I'm working on fixing the joints now, and so far five were not really bad.
What I mean is that the warning said a reference was lost and to edit the joint, but when I did there didn't seem to be anything wrong.
So I exited the form and the yellow warning shading went away.
I wish we wouldn't have to fix things that aren't broken.
Noah_Katz
Interesting, starting at the beginning of the timeline and fixing joints made later ones go from bad to good.
Revolute joints are working nicely now.
Noah_Katz
The cure is not quite complete.
No joints show warnings now, but as shown in the screencast, I cannot move the tensioner pivot unless I lock the main pivot joint.
Even before fixing the joints, sometimes I was able to do this.
@Manfred.Steinbach, any idea what the problem could be now?
Noah_Katz
let me try inserting that screencast again
@Noah_Katz
I can only guess because I have no access to your current model.
In my user-experience the "drag components with mouse" mode has its limits if the kinematic relationsships (kinematic model) are getting more complex. The use of "drive joints" gives you a better control - if the model then shows the expected movement, your joints should be ok.
Maybe you can try to control the (complex) kinematic movement with motion-links?  Or use motion-study, where you can alter the values of several joints for an (controlled) animation?
Noah_Katz
I don't really want or need to relate the individual motions.
it appears to be the same model that you posted before, same warnings and errors
Noah_Katz
@Anonymous
Oops, sorry, forgot about this.
I thought the link was live; when I made a new one, it was the same.
Maybe it just looks the same but isn't.
Anyway, everything works fine after cleaning up the warnings.
Thanks again.
@Noah_Katzwrote:
@Anonymous
Great! Glad to hear it worked. Thank you for the feedback. Smiley Happy
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
