Render window doesn't open
fprico
Message 1 of 9
fprico
This issue occurs quite often, the render window doesn't open, also the same issue happen with the render gallery it could not be opened. the issue happen after making a cloud or local render. After that every document I open have the same problem.
also at the top there is no option to save at this time.
Here is the model.
https://a360.co/2NB5a2B
Replies (8)
Message 2 of 9
jhackney1972
I do not have the same issue with you model.  Make sure your computer video drivers are up to date and give it another try. Attached is a .JPG of the in-canvas rendering of your supplied model.
Also below is the command for saving the rendered image on the Fusion 360 toolbar.
You must like "Red"!
John Hackney, Retired
Message 3 of 9
fprico
Yes the render window can be opened, but in my case the problem starts after doing some cloud renders.
Message 4 of 9
jhackney1972
I am confused, in your original post you said the problems you were having occurred in both "local" and cloud rendering.  Now you come back and say it only happens in cloud rendering.  I cannot test cloud rendering since I do not have access to cloud credits.
Message 5 of 9
fprico
If have to try if this happen with both. You can make a cloud render quality set to standard and a render size of 1000x700 In that settings its free to render. I Will try also with local render. Also If you make a render after that try to open the render window various times.
Message 6 of 9
fprico
Yes, after clicking in render various times 5 to 8 the problem start. open the render window and close it.
Message 7 of 9
fprico
here is an image, also close the the render Windows immediately after it loads.
Message 8 of 9
fprico
I think I have found when the error its produces, you have to press on render and then close the render Windows immediately before it completely loads.
Message 9 of 9
fprico
anyone?
