Navigate Data Panel to current open file.
LiveLover
LiveLover
I'm experiencing difficulties with finding file location.
May be there is a command to navigate Data Panel to the open file I'm looking at?
Now I find by name in Data Panel to get Project name. And then manually scan all the folders in it to find the file(
Thank you for any suggestions and comments.
Replies (7)
LiveLover
It would be nice to drop-down menu when we do right-mouse button click on file tabs. And item "show in data panel", like in many text editors/IDEs.
jeff_strater
this is not a great workaround, but Save As will bring up the project browser in the project that the active design lives.  I use that to help me find the current location.  Just bring up Save As, note the project, and cancel.
It's not perfect (does not show you what folder within that project), but it will help you at least find the project.
Jeff Strater
Engineering Director
LiveLover
Jeff!! "Save As" SHOWS full path! Yuhuu!
LiveLover
OH, NO! "Save As" isn't a workaround.
"Save As" shows us the last path opened in Data Panel. Nothing more!
May be subscription allows to find file location in predictable amount of clicks?
LiveLover
My solution!
If a file is open, you can see it in Recent Data.
In DataPanel right click -> Move ==> You see file location!
LiveLover
As @sasikanth.kollipara told Data Panel drop-down menu shows full file path
View details on Web shows them too
sasikanth.kollipara
Good, you found the solution you want in here: Data Panel drop-down menu shows full file path
Hit Like and Click "Accept solution", this would help others looking for the solution.
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
