Kurt dx6 machine vise models
brianneRYX92
brianneRYX92
Has anyone made a model for the Kurt dx6 vise?
I cant seem to find a supported file for fusion 360 on their website. Perhaps it's there and I'm not seeing it?
I appreciate your help.
Thank you
HughesTooling
I downloaded STP or STEP files awhile ago from their site.
Mark
Mark Hughes
Owner, Hughes Tooling
brianneRYX92
Will the STP, or STEP file import directly into fusion 360 without issues or modification?
HughesTooling
A bit more advice, after import I'd simplify and remove all the junk you don't need. I only wanted the model for CAM setup so removed all screws, engraving etc. The over complex model will just use up resources and slow Fusion down.
I ended up with just this, just 4 parts assembled with 3 joints.
Mark
Mark Hughes
HughesTooling
Yes, it will come in as an assembly. You might need to add joints if you want to move the jaws to fit other components. See advice in my post above.
Mark
Mark Hughes
brianneRYX92
Thanks a bunch!
