Hi, New user, downloaded the trial version and it just flashes when installing. Tried to uninstall and re-install on to avail. Copy of install log attached.. Any help?
2017-08-18 21:31:34,415 - MainProcess(5336) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-18 21:31:34,416 - MainProcess(5336) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-18 21:31:34,416 - MainProcess(5336) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001ED2EB20A20> #
2017-08-18 21:31:34,416 - MainProcess(5336) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-18 21:31:34,416 - MainProcess(5336) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-18 21:31:34,416 - MainProcess(5336) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zS3B6C.tmp\resources\buildinfo.json
2017-08-18 21:31:34,417 - MainProcess(5336) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-18 21:31:34,417 - MainProcess(5336) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-18 21:31:34,417 - MainProcess(5336) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-18 21:31:34,417 - MainProcess(5336) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-18 21:31:34,418 - MainProcess(5336) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zS3B6C.tmp\resources
2017-08-18 21:31:34,418 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000001ED2EB1AB70>, pipes=None, procfac=<function deploy_process at 0x000001ED2EB1A7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-18 21:31:34,419 - MainProcess(5336) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-18 21:31:34,558 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-18 21:31:36,040 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2017-08-18 21:31:36,045 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-18 21:31:36,045 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-18 21:31:36,048 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-18 21:31:36,104 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.94.209.211
2017-08-18 21:31:36,134 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-18 21:31:36,189 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuNy4xMTcuMTky
2017-08-18 21:31:36,344 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-18 21:31:36,345 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-18 21:31:36,345 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-18 21:31:36,428 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-18 21:31:36,429 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is 5d5a2d2b-e367-4483-bd58-6e6870548659
2017-08-18 21:31:36,548 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-18 21:31:36,548 - MainProcess(5336) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-18 21:31:36,552 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-18 21:31:36,553 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-18 21:31:36,556 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-18 21:31:36,556 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-18 21:31:36,638 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-18 21:31:36,638 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-18 21:31:36,638 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-18 21:31:36,738 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:36,738 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path does not exist. Creating
2017-08-18 21:31:36,752 - MainProcess(5336) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.ta... for package 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-18 21:31:36,752 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-18 21:31:36,752 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.js...
2017-08-18 21:31:36,862 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-18 21:31:36,862 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.js...
2017-08-18 21:31:36,864 - MainProcess(5336) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:36,876 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-18 21:31:36,876 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.ta... for package c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-18 21:31:36,954 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-18 21:31:36,954 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.ta... for package e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-18 21:31:36,954 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.js...
2017-08-18 21:31:37,019 - MainProcess(5336) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:37,073 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-18 21:31:37,073 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.js...
2017-08-18 21:31:37,073 - MainProcess(5336) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.ta... for package 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-18 21:31:37,112 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:37,249 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: efa280bbc1ef97da953b5f8191b1621102c34eaf
2017-08-18 21:31:37,249 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/efa280bbc1ef97da953b5f8191b1621102c34eaf.js...
2017-08-18 21:31:37,251 - MainProcess(5336) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:37,425 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 67517f33190c16903c7cd5ac34419e4a2fefac12
2017-08-18 21:31:37,425 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/67517f33190c16903c7cd5ac34419e4a2fefac12.js...
2017-08-18 21:31:37,577 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e56bd961cb6459164dadbfdad42272006c3e9e23
2017-08-18 21:31:37,577 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e56bd961cb6459164dadbfdad42272006c3e9e23.js...
2017-08-18 21:31:37,656 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-18 21:31:37,656 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.ta... for package 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-18 21:31:37,766 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 975d5afe6c6ab37eb02f43a55af5a3abe108f522
2017-08-18 21:31:37,766 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/975d5afe6c6ab37eb02f43a55af5a3abe108f522.js...
2017-08-18 21:31:37,885 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:37,939 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 59587e617a8696492d1aa452668ca74c69ed1689
2017-08-18 21:31:37,940 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/59587e617a8696492d1aa452668ca74c69ed1689.js...
2017-08-18 21:31:38,122 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1f1265374f514bdb9c75a6f793a163ba14c6c938
2017-08-18 21:31:38,122 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1f1265374f514bdb9c75a6f793a163ba14c6c938.js...
2017-08-18 21:31:38,148 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-18 21:31:38,149 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/efa280bbc1ef97da953b5f8191b1621102c34eaf.ta... for package efa280bbc1ef97da953b5f8191b1621102c34eaf
2017-08-18 21:31:38,307 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3f6267a0c82b19dae2d239b3bd6c757b78e87c1c
2017-08-18 21:31:38,307 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3f6267a0c82b19dae2d239b3bd6c757b78e87c1c.js...
2017-08-18 21:31:38,338 - MainProcess(5336) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-18 21:31:38,477 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: ba7f82e5c2ec3a9dbbdfbb20e27109639bcb6394
2017-08-18 21:31:38,477 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ba7f82e5c2ec3a9dbbdfbb20e27109639bcb6394.js...
2017-08-18 21:31:38,677 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3f699c0e1a69164e4ef155fa32683f0fda04ff78
2017-08-18 21:31:38,677 - MainProcess(5336) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3f699c0e1a69164e4ef155fa32683f0fda04ff78.js...
2017-08-19 06:44:18,862 - MainProcess(9592) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-19 06:44:18,865 - MainProcess(9592) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-19 06:44:18,865 - MainProcess(9592) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000016050890A58> #
2017-08-19 06:44:18,865 - MainProcess(9592) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-19 06:44:18,865 - MainProcess(9592) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-19 06:44:18,865 - MainProcess(9592) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zS4794.tmp\resources\buildinfo.json
2017-08-19 06:44:18,866 - MainProcess(9592) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-19 06:44:18,866 - MainProcess(9592) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-19 06:44:18,866 - MainProcess(9592) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-19 06:44:18,866 - MainProcess(9592) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-19 06:44:18,866 - MainProcess(9592) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zS4794.tmp\resources
2017-08-19 06:44:18,867 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-19 06:44:18,867 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-19 06:44:18,867 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000001605088AB70>, pipes=None, procfac=<function deploy_process at 0x000001605088A7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-19 06:44:18,868 - MainProcess(9592) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-19 06:44:19,095 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-19 06:44:20,729 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-08-19 06:44:20,729 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-19 06:44:20,729 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-19 06:44:20,744 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-19 06:44:20,797 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.194.7.34
2017-08-19 06:44:20,813 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-19 06:44:20,898 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMTk0LjcuMzQ=
2017-08-19 06:44:21,060 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-19 06:44:21,060 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-19 06:44:21,060 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-19 06:44:21,176 - MainProcess(9592) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 06:44:21,176 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is e3aa94a0-2971-47ea-808a-c1cf438d59c2
2017-08-19 06:44:21,298 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-19 06:44:21,298 - MainProcess(9592) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 06:44:21,298 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-19 06:44:21,314 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-19 06:44:21,314 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 06:44:21,314 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-19 06:44:21,851 - MainProcess(9592) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 06:44:21,851 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 06:44:21,851 - MainProcess(9592) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-19 08:42:26,807 - MainProcess(6636) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-19 08:42:26,807 - MainProcess(6636) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-19 08:42:26,807 - MainProcess(6636) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000024120A70A58> #
2017-08-19 08:42:26,808 - MainProcess(6636) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-19 08:42:26,808 - MainProcess(6636) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-19 08:42:26,808 - MainProcess(6636) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zS6EF4.tmp\resources\buildinfo.json
2017-08-19 08:42:26,808 - MainProcess(6636) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-19 08:42:26,809 - MainProcess(6636) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-19 08:42:26,809 - MainProcess(6636) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-19 08:42:26,809 - MainProcess(6636) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-19 08:42:26,809 - MainProcess(6636) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zS6EF4.tmp\resources
2017-08-19 08:42:26,809 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x0000024120A6AB70>, pipes=None, procfac=<function deploy_process at 0x0000024120A6A7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-19 08:42:26,810 - MainProcess(6636) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-19 08:42:26,811 - MainProcess(6636) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-19 08:42:26,929 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-19 08:42:28,351 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-08-19 08:42:28,351 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-19 08:42:28,351 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-19 08:42:28,354 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-19 08:42:28,481 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.194.7.34
2017-08-19 08:42:28,512 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-19 08:42:28,666 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMTk0LjcuMzQ=
2017-08-19 08:42:28,832 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-19 08:42:28,832 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-19 08:42:28,832 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-19 08:42:28,951 - MainProcess(6636) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:42:28,952 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is 8d7113d9-8b4b-4ebc-bb9b-84c8914e6b80
2017-08-19 08:42:29,064 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-19 08:42:29,064 - MainProcess(6636) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:42:29,068 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-19 08:42:29,068 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-19 08:42:29,069 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:42:29,069 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-19 08:42:29,191 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:42:29,191 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:42:29,191 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-19 08:42:29,311 - MainProcess(6636) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.ta... for package 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:42:29,311 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:42:29,311 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.js...
2017-08-19 08:42:29,321 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:42:29,323 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acge223.dll. REMOVING
2017-08-19 08:42:29,444 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 08:42:29,444 - MainProcess(6636) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.ta... for package c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:42:29,444 - MainProcess(6636) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.js...
2017-08-19 08:42:29,450 - MainProcess(6636) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:42:29,451 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acgex223.dll. REMOVING
2017-08-19 08:42:29,452 - MainProcess(6636) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\enginio_ad_5.dll. REMOVING
2017-08-19 08:42:29,467 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\gelib.manifest. REMOVING
2017-08-19 08:42:29,469 - MainProcess(6636) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001FEA6C70A58> #
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-19 08:43:41,765 - MainProcess(4900) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zS9738.tmp\resources\buildinfo.json
2017-08-19 08:43:41,766 - MainProcess(4900) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-19 08:43:41,766 - MainProcess(4900) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-19 08:43:41,766 - MainProcess(4900) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-19 08:43:41,766 - MainProcess(4900) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-19 08:43:41,767 - MainProcess(4900) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zS9738.tmp\resources
2017-08-19 08:43:41,767 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-19 08:43:41,767 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-19 08:43:41,767 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000001FEA6C6AB70>, pipes=None, procfac=<function deploy_process at 0x000001FEA6C6A7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-19 08:43:41,768 - MainProcess(4900) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-19 08:43:41,863 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-19 08:43:43,148 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-08-19 08:43:43,148 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-19 08:43:43,148 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-19 08:43:43,151 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-19 08:43:43,303 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.194.7.34
2017-08-19 08:43:43,344 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-19 08:43:43,360 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMTk0LjcuMzQ=
2017-08-19 08:43:43,520 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-19 08:43:43,520 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-19 08:43:43,520 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-19 08:43:43,650 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:43:43,652 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is d33b4957-59e3-4ab9-9a71-392db0ee7a11
2017-08-19 08:43:43,761 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-19 08:43:43,761 - MainProcess(4900) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:43:43,765 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-19 08:43:43,766 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-19 08:43:43,767 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:43:43,767 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-19 08:43:43,890 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:43:43,894 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:43:43,894 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-19 08:43:44,021 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:43:44,022 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acge223.dll. REMOVING
2017-08-19 08:43:44,023 - MainProcess(4900) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.ta... for package 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:43:44,024 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:43:44,024 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.js...
2017-08-19 08:43:44,149 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acgex223.dll. REMOVING
2017-08-19 08:43:44,155 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 08:43:44,156 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.js...
2017-08-19 08:43:44,156 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.ta... for package c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:43:44,162 - MainProcess(4900) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:43:44,162 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\gelib.manifest. REMOVING
2017-08-19 08:43:44,163 - MainProcess(4900) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\enginio_ad_5.dll. REMOVING
2017-08-19 08:43:44,164 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 08:43:44,213 - MainProcess(4900) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\icudt55.dll. REMOVING
2017-08-19 08:43:44,286 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:43:44,288 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 08:43:44,288 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.js...
2017-08-19 08:43:44,289 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.ta... for package e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 08:43:44,290 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunits-16.dll. REMOVING
2017-08-19 08:43:44,401 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunitsui-16.dll. REMOVING
2017-08-19 08:43:44,450 - MainProcess(4900) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adexmtsv.exe. REMOVING
2017-08-19 08:43:44,468 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-19 08:43:44,468 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.js...
2017-08-19 08:43:44,469 - MainProcess(4900) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.ta... for package 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 08:43:44,474 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:43:44,476 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces-ad-c_3.dll. REMOVING
2017-08-19 08:43:44,703 - MainProcess(4900) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:43:44,704 - MainProcess(4900) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asm.manifest. REMOVING
2017-08-19 08:43:44,706 - MainProcess(4900) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmahl223a.dll. REMOVING
2017-08-19 08:43:44,707 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: efa280bbc1ef97da953b5f8191b1621102c34eaf
2017-08-19 08:43:44,707 - MainProcess(4900) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/efa280bbc1ef97da953b5f8191b1621102c34eaf.js...
2017-08-19 08:43:44,760 - MainProcess(4900) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces-ad-c_3d.dll. REMOVING
2017-08-19 08:47:27,747 - MainProcess(4676) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-19 08:47:27,748 - MainProcess(4676) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-19 08:47:27,748 - MainProcess(4676) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002C86C8E0B00> #
2017-08-19 08:47:27,748 - MainProcess(4676) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-19 08:47:27,748 - MainProcess(4676) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-19 08:47:27,748 - MainProcess(4676) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zSA08.tmp\resources\buildinfo.json
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zSA08.tmp\resources
2017-08-19 08:47:27,749 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-19 08:47:27,750 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-19 08:47:27,750 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-19 08:47:27,750 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000002C86C8DBB70>, pipes=None, procfac=<function deploy_process at 0x000002C86C8DB7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-19 08:47:27,751 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-19 08:47:27,751 - MainProcess(4676) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-19 08:47:27,751 - MainProcess(4676) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-19 08:47:27,751 - MainProcess(4676) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-19 08:47:27,751 - MainProcess(4676) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-19 08:47:27,849 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-19 08:47:29,128 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-08-19 08:47:29,129 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-19 08:47:29,129 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-19 08:47:29,131 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-19 08:47:29,266 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.207.242.208
2017-08-19 08:47:29,326 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-19 08:47:29,394 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuNy4xMTcuMTky
2017-08-19 08:47:29,551 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-19 08:47:29,552 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-19 08:47:29,552 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-19 08:47:29,657 - MainProcess(4676) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:47:29,658 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is 43a567c6-2261-460a-8531-5764fe710c5a
2017-08-19 08:47:29,768 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-19 08:47:29,769 - MainProcess(4676) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 08:47:29,770 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-19 08:47:29,773 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-19 08:47:29,773 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:47:29,774 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-19 08:47:29,859 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 08:47:29,859 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:47:29,859 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-19 08:47:29,958 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:47:29,960 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acge223.dll. REMOVING
2017-08-19 08:47:29,964 - MainProcess(4676) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.ta... for package 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 08:47:29,964 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:47:29,969 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.js...
2017-08-19 08:47:30,042 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acgex223.dll. REMOVING
2017-08-19 08:47:30,049 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\gelib.manifest. REMOVING
2017-08-19 08:47:30,050 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 08:47:30,060 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 08:47:30,060 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.ta... for package c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 08:47:30,060 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.js...
2017-08-19 08:47:30,065 - MainProcess(4676) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:47:30,067 - MainProcess(4676) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\enginio_ad_5.dll. REMOVING
2017-08-19 08:47:30,099 - MainProcess(4676) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\icudt55.dll. REMOVING
2017-08-19 08:47:30,149 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 08:47:30,149 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.js...
2017-08-19 08:47:30,151 - MainProcess(4676) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.ta... for package e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 08:47:30,156 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:47:30,158 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunits-16.dll. REMOVING
2017-08-19 08:47:30,226 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunitsui-16.dll. REMOVING
2017-08-19 08:47:30,271 - MainProcess(4676) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adexmtsv.exe. REMOVING
2017-08-19 08:47:30,291 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-19 08:47:30,291 - MainProcess(4676) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.ta... for package 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 08:47:30,291 - MainProcess(4676) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.js...
2017-08-19 08:47:30,309 - MainProcess(4676) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 08:47:30,310 - MainProcess(4676) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces-ad-c_3.dll. REMOVING
2017-08-19 11:18:20,112 - MainProcess(8288) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-19 11:18:20,112 - MainProcess(8288) - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-19 11:18:20,112 - MainProcess(8288) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000024F438F0A58> #
2017-08-19 11:18:20,113 - MainProcess(8288) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-19 11:18:20,113 - MainProcess(8288) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Ted\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-19 11:18:20,113 - MainProcess(8288) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Ted\AppData\Local\Temp\7zS2726.tmp\resources\buildinfo.json
2017-08-19 11:18:20,113 - MainProcess(8288) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-19 11:18:20,114 - MainProcess(8288) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-19 11:18:20,114 - MainProcess(8288) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170718021200
2017-08-19 11:18:20,114 - MainProcess(8288) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-19 11:18:20,114 - MainProcess(8288) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Ted\AppData\Local\Temp\7zS2726.tmp\resources
2017-08-19 11:18:20,114 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-08-19 11:18:20,115 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-08-19 11:18:20,115 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-08-19 11:18:20,115 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x0000024F438EAB70>, pipes=None, procfac=<function deploy_process at 0x0000024F438EA7B8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2017-08-19 11:18:20,115 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-08-19 11:18:20,115 - MainProcess(8288) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-08-19 11:18:20,116 - MainProcess(8288) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-08-19 11:18:20,116 - MainProcess(8288) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-08-19 11:18:20,116 - MainProcess(8288) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-19 11:18:20,226 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-08-19 11:18:21,622 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-08-19 11:18:21,622 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-08-19 11:18:21,622 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2017-08-19 11:18:21,625 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-08-19 11:18:21,689 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 96.17.44.62
2017-08-19 11:18:21,729 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-08-19 11:18:21,791 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: OTYuMTcuNDQuNjI=
2017-08-19 11:18:21,949 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I: MTc0LjU4Ljk0LjIwMg==
2017-08-19 11:18:21,949 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTAuMC4wLjI=
2017-08-19 11:18:21,949 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-08-19 11:18:22,081 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 11:18:22,082 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: The session id is 0484547c-1639-4499-985b-270831715c21
2017-08-19 11:18:22,193 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Configure app begin Deploy to 2.0.3254 for app 73e72ada57b7480280f7a6f4a289729f
2017-08-19 11:18:22,194 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3254']
2017-08-19 11:18:22,195 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-19 11:18:22,198 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.platform - INFO :: Required OS version: [6, 1]
2017-08-19 11:18:22,199 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 11:18:22,199 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.js...
2017-08-19 11:18:22,344 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e0ace3c76f049c538f20df51d10419ec2c697f9a.ta... for package e0ace3c76f049c538f20df51d10419ec2c697f9a
2017-08-19 11:18:22,344 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 11:18:22,344 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.js...
2017-08-19 11:18:22,501 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d05c48c3db8738107ec9d2e1fc6b5badd448497.ta... for package 1d05c48c3db8738107ec9d2e1fc6b5badd448497
2017-08-19 11:18:22,502 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 11:18:22,505 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.js...
2017-08-19 11:18:22,507 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:22,520 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acge223.dll. REMOVING
2017-08-19 11:18:22,652 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 11:18:22,652 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c2e65365584db962e9f88242c4df2b63ee8718e0.ta... for package c2e65365584db962e9f88242c4df2b63ee8718e0
2017-08-19 11:18:22,652 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.js...
2017-08-19 11:18:22,658 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:22,658 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\acgex223.dll. REMOVING
2017-08-19 11:18:22,678 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\enginio_ad_5.dll. REMOVING
2017-08-19 11:18:22,687 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\gelib\223.0.1.2500_m140\win64\gelib.manifest. REMOVING
2017-08-19 11:18:22,688 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 11:18:22,751 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\icudt55.dll. REMOVING
2017-08-19 11:18:22,804 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:22,820 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunits-16.dll. REMOVING
2017-08-19 11:18:22,835 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 11:18:22,835 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e3e3897fc8d31205cccbad06d757f4dfca7d98a6.ta... for package e3e3897fc8d31205cccbad06d757f4dfca7d98a6
2017-08-19 11:18:22,835 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.js...
2017-08-19 11:18:23,005 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adcoreunitsui-16.dll. REMOVING
2017-08-19 11:18:23,020 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-19 11:18:23,020 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.js...
2017-08-19 11:18:23,020 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5.ta... for package 3c3c6b013bfd6101fea12fed9a4447a5f7c2f1f5
2017-08-19 11:18:23,036 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:23,052 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces-ad-c_3.dll. REMOVING
2017-08-19 11:18:23,052 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\adexmtsv.exe. REMOVING
2017-08-19 11:18:23,190 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:23,206 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: efa280bbc1ef97da953b5f8191b1621102c34eaf
2017-08-19 11:18:23,206 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/efa280bbc1ef97da953b5f8191b1621102c34eaf.js...
2017-08-19 11:18:23,208 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asm.manifest. REMOVING
2017-08-19 11:18:23,217 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmahl223a.dll. REMOVING
2017-08-19 11:18:23,238 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces-ad-c_3d.dll. REMOVING
2017-08-19 11:18:23,305 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\xerces\3.1.4\win64_1\xerces.manifest. REMOVING
2017-08-19 11:18:23,305 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 11:18:23,305 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2ce05d7811535c90827d93f8faa1c0c34d3a051d.ta... for package 2ce05d7811535c90827d93f8faa1c0c34d3a051d
2017-08-19 11:18:23,407 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 67517f33190c16903c7cd5ac34419e4a2fefac12
2017-08-19 11:18:23,407 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/67517f33190c16903c7cd5ac34419e4a2fefac12.js...
2017-08-19 11:18:23,537 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:23,544 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\vcs\180.5.1\win64\vcs.dll. REMOVING
2017-08-19 11:18:23,565 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmbase223a.dll. REMOVING
2017-08-19 11:18:23,589 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmblnd223a.dll. REMOVING
2017-08-19 11:18:23,638 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: e56bd961cb6459164dadbfdad42272006c3e9e23
2017-08-19 11:18:23,638 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e56bd961cb6459164dadbfdad42272006c3e9e23.js...
2017-08-19 11:18:23,807 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmbool223a.dll. REMOVING
2017-08-19 11:18:23,869 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 975d5afe6c6ab37eb02f43a55af5a3abe108f522
2017-08-19 11:18:23,869 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/975d5afe6c6ab37eb02f43a55af5a3abe108f522.js...
2017-08-19 11:18:23,888 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\vcs\180.5.1\win64\vcs.manifest. REMOVING
2017-08-19 11:18:23,890 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-08-19 11:18:23,890 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/efa280bbc1ef97da953b5f8191b1621102c34eaf.ta... for package efa280bbc1ef97da953b5f8191b1621102c34eaf
2017-08-19 11:18:23,922 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmcovr223a.dll. REMOVING
2017-08-19 11:18:23,938 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmcstr223a.dll. REMOVING
2017-08-19 11:18:24,006 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmct223a.dll. REMOVING
2017-08-19 11:18:24,021 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmdatax223a.dll. REMOVING
2017-08-19 11:18:24,052 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmdefm223a.dll. REMOVING
2017-08-19 11:18:24,068 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmeulr223a.dll. REMOVING
2017-08-19 11:18:24,089 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 59587e617a8696492d1aa452668ca74c69ed1689
2017-08-19 11:18:24,089 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/59587e617a8696492d1aa452668ca74c69ed1689.js...
2017-08-19 11:18:24,090 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmfct223a.dll. REMOVING
2017-08-19 11:18:24,127 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\icuin55.dll. REMOVING
2017-08-19 11:18:24,128 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Ted\AppData\Local\Autodesk\webdeploy\shared
2017-08-19 11:18:24,128 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmfrec223a.dll. REMOVING
2017-08-19 11:18:24,128 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\py.ico. REMOVING
2017-08-19 11:18:24,144 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\pyc.ico. REMOVING
2017-08-19 11:18:24,144 - MainProcess(8288) - Thread-1 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\airmax\bb17.3_0614\win64\admaterialui.dll. REMOVING
2017-08-19 11:18:24,182 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmga223a.dll. REMOVING
2017-08-19 11:18:24,190 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmheal223a.dll. REMOVING
2017-08-19 11:18:24,190 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\pyexpat.pyd. REMOVING
2017-08-19 11:18:24,225 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\icuuc55.dll. REMOVING
2017-08-19 11:18:24,250 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmimport223a.dll. REMOVING
2017-08-19 11:18:24,260 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\select.pyd. REMOVING
2017-08-19 11:18:24,265 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\sqlite3.dll. REMOVING
2017-08-19 11:18:24,290 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\libegl.dll. REMOVING
2017-08-19 11:18:24,290 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmintr223a.dll. REMOVING
2017-08-19 11:18:24,306 - MainProcess(8288) - Thread-5 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\qt\5.5.0-20160219-qtapps\win64\libglesv2.dll. REMOVING
2017-08-19 11:18:24,306 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 1f1265374f514bdb9c75a6f793a163ba14c6c938
2017-08-19 11:18:24,306 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1f1265374f514bdb9c75a6f793a163ba14c6c938.js...
2017-08-19 11:18:24,406 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\tcl86t.dll. REMOVING
2017-08-19 11:18:24,437 - MainProcess(8288) - Thread-4 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\asm\223.11.0_m140\win64\asmkern223a.dll. REMOVING
2017-08-19 11:18:24,507 - MainProcess(8288) - Thread-2 - adsk.dls.streamer.process - WARNING :: Trying to extract on top of existing file \\?\c:\users\ted\appdata\local\autodesk\webdeploy\shared\python\3.5.3c\win64\python\dlls\tk86t.dll. REMOVING
2017-08-19 11:18:24,570 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling package manifest: 3f6267a0c82b19dae2d239b3bd6c757b78e87c1c
2017-08-19 11:18:24,570 - MainProcess(8288) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3f6267a0c82b19dae2d239b3bd6c757b78e87c1c.js...
Solved by saito.kh. Go to Solution.
Hello @Anonymous,
Welcome to the Fusion 360 community!
I am sorry to hear you are experiencing this difficulty.
Can you please gather the Diagnostic Log files and share them with private message to me?
It would help me to troubleshoot this behavior. The below link details how to gather the log files manually:
** Before gathering the Diagnostic Log files, please try clean-uninstalling and re-installing as the below steps if you have not tried. Hope this helps.
1) Remove Fusion with clean utility in this link.
2) Download a fresh installer from "DOWNLOAD FREE TRIAL" at here and save it on your desktop.
3) Right-click on the program, and select "Run as Administrator" from the menu.
4) Complete installing and launch Fusion.
If you have any questions, please let me know!
Thanks!
