Hi Everyone
How can I hide faces in a body so I can select faces underneath?
I want to select the whole wheel and make that a new body?
thx heaps
Solved by paul.clauss. Go to Solution.
Thanks for posting!
While you cannot hide faces in Fusion 360, you could use the "Select Other" tool to select faces underneath a body. To activate the "Select Other" tool, simply hold down the left mouse button while the cursor is over the face you wish to select, even if it is behind a body. A list of possible selections will be shown and you will be able to select the face there:
Hopefully this helps! Please let me know if you have any questions.
Thanks so much Paul it's the little tricky things like that you don't find by yourself 🙂
