Fusion 360 Simulation wont allow me to solve
AlbinBlavin
Message 1 of 14
AlbinBlavin
I have unlimited cloud credits, and the study is working. But i cant press the solve button.
Replies (13)
Message 2 of 14
TheCADWhisperer
Message 3 of 14
AlbinBlavin
I posted it.
Message 4 of 14
TheCADWhisperer
Message 5 of 14
AlbinBlavin
I removed the load and it didnt work. I turned on "Remove rigid body modes" with and without the constraint and it didnt work either.
Message 6 of 14
simon-michael.weishaeupl
Observer
Observer
same problem here right now. seems to be a cloud issue?
Message 7 of 14
mqltd
It appears no type of simulation will start today. Previous successful models fail also. Looks like it can't access the Cloud to even accept the data. Not a problem in model setup.
Message 8 of 14
dsouzasujay
Hi @simon-michael.weishaeupl  @AlbinBlavin  @mqltd
Fusion 360 solved without problems both 'Cloud' and 'Local'.
At this stage, I assume you are running Fusion on the newer version 2.0.12376
Can you please send me the log files
Edit:
I can see the issue now on build 2.0.12376, i will check with the development team and get back.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 14
AlbinBlavin
It appears to be working again
Message 10 of 14
dsouzasujay
@AlbinBlavin @mqltd @simon-michael.weishaeupl
Working now, Please check.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 14
mqltd
Simulations running OK for me now. Thanks for fixing.
Message 12 of 14
jonfuentes47
Community Visitor
Community Visitor
Same issue as mentioned before in the chat. Simulations have not been running for 24 hours even with previous successful models.
2.0.14337
Plano activo: Fusion 360, Estudiante
Windows 10 Home 21H1 x86_64 (19043.2130)
Message 13 of 14
dsouzasujay
Hi @jonfuentes47
Sorry to see that you're facing this problem.
We are currently experiencing issues with cloud solves for Simulation and GD. This is actively being investigated as top priority. I will update you once the issue is resolved.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 14 of 14
dsouzasujay
Hi @jonfuentes47
Can you give a try to solve again, Looks like already its been fixed.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
