Fusion 360 Keeps crashing on startup unable to resolve problem.
20210526T174432 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/NMachineSpecificOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174433 I Version : 2.0.10148
20210526T174433 I UTC offset : -7
20210526T174433 I Loading configuration from:C:/Users/ericw/AppData/Local/Autodesk/webdeploy/production/9b196c6eb71126665f61dbf5a4b48d188eb6263c/Fusion 360.server.config
20210526T174434 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/CJMZK8U73VSF/NGlobalOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174434 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/NMachineSpecificOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174434 I SLM: device id = 5d2bd756-8729-61a4-6125-908ea225015c
20210526T174434 I SLM: Initialized
20210526T174434 I WorkflowTrackManager Initialized with:0 items
20210526T174434 I Disk capacity: 975,684MB Disk free: 754,673MB Percentage free: 77 UIThread: no Time: 0.00026s
20210526T174434 I ADP - 80175225-020e-4d59-afce-6ae238fca98a
20210526T174434 I AnalyticItemCounts Initialized with:0 items
20210526T174434 I searchAndLoad exec path: C:/Users/ericw/AppData/Local/Autodesk/webdeploy/production/9b196c6eb71126665f61dbf5a4b48d188eb6263c/Fusion360.exe
20210526T174434 I PROXY: WindowsProxyOptionId set to Automatic ThreadID: 6816, Function: `anonymous-namespace'::logProxyOpIfChanged, Line: 920
20210526T174434 W PROXY: failed to query IE proxy configuration - The Proxy Auto-configuration URL was not found.
20210526T174434 I PROXY: proxy server set to DIRECT ThreadID: 6816, Function: `anonymous-namespace'::logProxyUsedIfChanged, Line: 947
20210526T174434 I SYNHUB: Loading config files in directory C:/Users/ericw/AppData/Roaming/Autodesk/Synergy
20210526T174434 I SYNHUB: Loading config file C:/Users/ericw/AppData/Roaming/Autodesk/Synergy/NLauncher.syncfg
20210526T174434 I Request(https://ui-dls360.autodesk.com/fusion/version.txt) - workflow: attempt:0 status:200 requestId:
20210526T174434 I Request(https://a360-statusdashboard.s3.amazonaws.com/autodesk_maintenance.json) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-60aeeb71-4802869e18f94e2a8ad647ec
20210526T174434 I Request(https://ui-dls360.autodesk.com/fusion/maintenace_services.txt) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-60aeeb71-76e027f58dd74af8b31dd27f
20210526T174435 I LaunchDarkly client initialization process is finished successfully! ThreadID: 12796, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 341
20210526T174435 I LD CSDK for type Global was initialized with a total time of 0.000002 seconds ThreadID: 13836, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 141
20210526T174436 I Load Feature Toggle Xml:C:/Users/ericw/AppData/Local/Autodesk/webdeploy/production/9b196c6eb71126665f61dbf5a4b48d188eb6263c/Fusion/Server/Fusion/Resources/FeatureToggle/FeatureToggle.xml
20210526T174436 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/CJMZK8U73VSF/NGlobalOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174436 I Load Feature Toggle Xml:C:/Users/ericw/AppData/Local/Autodesk/webdeploy/production/9b196c6eb71126665f61dbf5a4b48d188eb6263c/FusionDoc/Server/FusionDoc/Resources/FeatureToggle/FeatureToggle.xml
20210526T174436 I C:\Users\ericw\AppData\Local\Autodesk\webdeploy\production\9b196c6eb71126665f61dbf5a4b48d188eb6263c\Applications\Simulation\SimCommon10.dll ThreadID: 15680, Function: DllMain, Line: 22
20210526T174436 I Process attach ThreadID: 15680, Function: DllMain, Line: 23
20210526T174437 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/NMachineSpecificOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174437 I C:\Users\ericw\AppData\Local\Autodesk\webdeploy\production\9b196c6eb71126665f61dbf5a4b48d188eb6263c\Applications\CAM360\SimIdealizations10.dll ThreadID: 15680, Function: DllMain, Line: 16
20210526T174437 I Process attach ThreadID: 15680, Function: DllMain, Line: 17
20210526T174437 I Libeagle app mode: Hosted ThreadID: 15680, Function: void __cdecl Application::cEagleAppPrivate::Init(void), Line: 315
20210526T174438 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/CJMZK8U73VSF/electronoptiongroup_eagle.rc successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174438 I Just loaded Options file C:/Users/ericw/AppData/Roaming/Autodesk/Neutron Platform/Options/CJMZK8U73VSF/NGlobalOptions.xml successfully ThreadID: 15680, Function: Ns::OptionGroup::load, Line: 616
20210526T174438 D DrawingPIMMgrEventsHandler/subscribe: ENTERING
20210526T174438 D DrawingPIMMgrEventsHandler/subscribe: EXITING
20210526T174438 D PIMMgrEventsHandler/subscribe: ENTERING
20210526T174438 D PIMMgrEventsHandler/subscribe: EXITING
20210526T174438 I Toolbar loader: Stopping...
20210526T174438 I Toolbar loader: Stopped
20210526T174438 I ***startSession: BEGIN
20210526T174438 I the maintenance window is OFF
20210526T174438 I getEntitlement
20210526T174438 I authenticate:begin
20210526T174438 I login start
20210526T174438 I Going to load toolbar customizations files ThreadID: 15680, Function: Nu::ToolbarManager::loadCustomization, Line: 426
20210526T174438 I Completed loading toolbar customizations files ThreadID: 15680, Function: Nu::ToolbarManager::loadCustomization, Line: 428
20210526T174438 I AnalyticItemCounts Terminating with:0 items
20210526T174438 I AnalyticItemCounts Initialized with:0 items
20210526T174438 I WorkflowTrackManager Terminating with:0 items
20210526T174438 I WorkflowTrackManager Initialized with:0 items
20210526T174438 D PIMMgrEventsHandler/onAuthenticated: ENTERING
20210526T174438 D PIMMgrEventsHandler/onAuthenticated: EXITING
20210526T174438 I login end 0
20210526T174438 I Autosave background thread started with saveTime: 5
20210526T174438 I LaunchDarkly client initialization process is not finished successfully! ThreadID: 13836, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 345
20210526T174438 I Request(https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-60aeeb75-5d919e99d01f44d48f9ac2d8
20210526T174438 I SLM: Enabled (Production)
20210526T174438 I SLM: Start session deviceId=5d2bd756-8729-61a4-6125-908ea225015c deviceName=Surface-Book-3
20210526T174438 I Workflow start: SLM_startSession 1-60aeeb75-c183ae5ec58e41f88138fd16
20210526T174438 I LaunchDarkly client initialization process is finished successfully! ThreadID: 12796, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 341
20210526T174438 I LD CSDK for type Nonhub was initialized with a total time of 0.333610 seconds ThreadID: 13836, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 141
20210526T174438 I LD CSDK for type Nonhub was initialized with a total time of 0.000002 seconds ThreadID: 13836, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 141
20210526T174438 I Request(https://f360sc-p-ue1.api.cosv2-p-ue1-dn.autodesk.com/api/v1/sessions) - workflow:SLM_startSession attempt:0 status:200 requestId:f360_SLM_startSession__1-60aeeb75-c183ae5ec58e41f88138fd16
20210526T174438 I SLM: session = 21631648
@ewilliams361 Can you try some of the solutions I called out in this thread?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I have tried every suggestion in that thread and others nothing has worked.
@ewilliams361 Are you getting any crash reports to submit when it crashes? If so can you give me a report ID that I can go of? What happens if you launch Fusion 360 in offline state with no internet? Does it change make a difference? There is a clean uninstall option of Fusion 360 but want to see if anything else can fix this for you.
Autodesk Fusion
Join Fusion Insider
I submitted my crash report its in my post did you read it. Offline mode still crashes.
@ewilliams361 I don't see any reports in our backend based on your email ID. I don't see any reference to a crash report ID in your original post either. Do you mind sharing a report ID that I can query of?
Autodesk Fusion
Join Fusion Insider
@ewilliams361 OK. That is not what I am looking for. It looks like you did not get the crash error report to send it to Autodesk then.
Autodesk Fusion
Join Fusion Insider
Where is the crash error repot what I posted is literally called the crash log in system files?
@ewilliams361 This is he product crash report that I was looking for. From your comments it looks like you did not receive one. Still investigating what else we can try.
Autodesk Fusion
Join Fusion Insider
Uninstalling and reinstalling solved the problem.
When will Fusion 360 support native RTX Quadro graphics cards. I see almost zero improvement with my Quadro card on my Surface Book 3?
The crashing problem is back it is your update. Update stops at 14% and then crashes and closes 360. This is getting extremely annoying. Is there a fix is this a known problem yet?
