fusion 360 - Extrude to object
Message 1 of 11
hello I'm new in fusion 360 I have a problem when I'm using extrude to object  I get this massage
Cannot extend extrusion to object. The extrusion profile falls outside the boundary of the selected body. Select a face or plane instead, or adjust the profile so that it falls inside the boundary of the selected body
how I can fix it
Replies (10)
Message 2 of 11
jeff_strater
can you share your model here?  And a screencast of what you are doing?  Without that, it is very difficult to tell what is going on.  Most likely, changing the "extend" setting may help:
Jeff Strater
Engineering Director
Message 3 of 11
Message 4 of 11
jhackney1972
You are misunderstanding what @jeff_strater requested.  You need to share the actual model with the forum community by attaching it to your forum post.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 5 of 11
jeff_strater
@Anonymous - what are you trying to achieve here?  Are you just trying to hollow out the part of the design in red?  In addition to the model, we need to understand what your desired result is, because there may be better ways to achieve it.
Jeff Strater
Message 6 of 11
  I'm actually going to go down minus four and I'm going to cut that material out four millimeters
Message 7 of 11
Message 8 of 11
Message 9 of 11
this is my file
Message 10 of 11
jeff_strater
thanks.  It seemed to work OK for me.  Am I doing something different?  Model is attached.
screencast:
Jeff Strater
Message 11 of 11
when I'm using your file its work without problem
thank you very much
