I know, I know, it is not supposed to run there, that same computer also boots Windows and there it runs fine, I just have to reboot the computer and problem solved, just wanted to let you know in case there is a simple way to fix it without degrading performance, or something I can do in my computer to make it run. I'm setting up NAS servers in FreeBSD and it's just easier in MacOS, my real MacPro is just too heavy to carry everywere.
Solved by hmaleville. Go to Solution.
Can you detail the behaviour you have from the App? I've also a Ryzen machine and it stopped working with SEG FAULT after each attempt. I've tried to uninstall/clean/reinstall to no avail....
Yes, of course; when I try to open the program it closes immediately and requests permission to send the crash to Apple, from that info got this:
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00007ffedfc53ff8
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1895]
I've also tried a clean reinstall but no, it still crashes the same. On Intel Hackintosh and real Macs it does work ok, so I think last version may have some compilation optimizations for Intel that were not done before.
I can't remember which version Opencore I'm running but it is not a recent one (if it works, do not touch it).
@GroovyDrifter, you can try overriding the OpenGL renderer used when starting Fusion 360 with an environment variable via the Terminal command below, where variable would be replaced with angle (default), desktop (hardware GPU driver), or software (CPU):
export QT_OPENGL=variable && open ~/Applications/Autodesk\ Fusion\ 360.app
If desktop or software work, you can make this variable permanent, but please know it may affect other Qt-based applications.
None of the options work. Still crashing with EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_PROTECTION_FAILURE at 0x00007ffeeb125ff8.
Could you instead review what code change was made and revert to a portable solution? It looks like same problem already occurs last year.
From the crash report, there is a call to _intel_fast_memset, which results in a call stack overflow, probably because the binary code is intel specific. So my guess is that you have turned on an Intel specific optimization in your compilation process.
Thanks.
It looks like it's related to the "AIRMAX" module, which now includes the Intel® Threading Building Blocks library (may be related to an O2 compiler flag)...
Sorry for the SPAM.... I don't know what the problem is with these libraries but I've replaced them with the ones provided by BREW and Fusion 360 is back to life (until your next update)....
@GroovyDrifter You may use this workaround ("brew install tbb", "brew list tbb" to get the location, then copy the .dylib files to ~/Library/Application Support/Autodesk/webdeploy/production/xxxxx/Autodesk Fusion 360.app/Contents/Framework/AIRMAX/ where xxxxx is probably a unique specific GUID).
Our April update included an update to the AIRMAX module, so that makes sense. I can inquire if dependency on that library was a conscious decision or not.
I must be transparent, though - as AIRMAX is a shared component across multiple applications, and device configurations like Hackintoshes are rare/unsupported by the OEM, I cannot make any guarantees around fixing this issue, if for no other reason than we only have retail Intel- and Apple silicon-based macOS devices to debug on.
I'll try your fix this afternoon, but surely it will work (Edit: confirmed, it worked). My fix was much more rudimentary, I copied the full app from a High Sierra computer 🙂
If Autodesk needs someone with a suitable system to check a fix for this, I'm almost all the day at home with all the COVID19 thing messing with our lives so I can do it.
Just updated to:
2.0.10148
Active Plan: Fusion 360, Subscription
macOS 10.15.7
The problem persists, @hmaleville fix still works 😊
Just wanna thank @hmaleville for the fix, I think I had uninstalled and reinstalled Fusion360 via homebrew 10 times already.
Awesome thread! The Ryzentosh family is bigger than I thought 😁
I tried the same but got the following exception:
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: DYLD, [0x4] Symbol missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Symbol not found: __ZN3tbb4task13note_affinityEt
Referenced from: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/../Frameworks/ASM/libASMbase227A.dylib
Expected in: /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/../Frameworks/AIRMAX/libtbb.dylib
in /Users/USER/Library/Application Support/Autodesk/*/Autodesk Fusion 360.app/Contents/MacOS/../Frameworks/ASM/libASMbase227A.dylib
I used TBB v2021.2.0.
Ah ok so you are using a different version I think. I installed it with brew.
otool -L /usr/local/Cellar/tbb/2021.2.0/lib/libtbb.dylib
/usr/local/Cellar/tbb/2021.2.0/lib/libtbb.dylib:
/usr/local/opt/tbb/lib/libtbb.12.dylib (compatibility version 12.0.0, current version 12.2.0)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 902.1.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1281.100.1)
I will try to find your version.
I solved the issue. Make sure you install the correct version:
brew install tbb@2020
that did the trick for me version 2020, thanks.
brew list tbb@2020
and then copy that to the airmax folder:
/Users/user/Library/Application Support/Autodesk/webdeploy/production/xxxx/Autodesk Fusion 360.app/Contents/Frameworks/AIRMAX
Running:
2.0.10253
Active Plan: Fusion 360, Personal
macOS 10.16.0
