Fusion 360 can't save. It just says "Activate Component"
How do I save  .stl   files ?  I am using Fusion 360.  I can save file but not  stl file.
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the forums!
I'm not entirely sure what you are asking - have you tried saving a .stl using this method? : click here for link
Here's a little gif showing you how to right click and select "save as .stl" on either the parent component or the child component.
You also might be interested in taking a look at this video that explains the difference between components and bodies, and shows how to activate a component. Link
Let me know if that solved your problem or if you need more information!
