Fix constraint missing
Ex_Machina_Engineering
Hello guys,
I'm using the new UI (which I really like) and in the sketch environment, the constraints buttons are all moved to the ribbon. So no menu on the right side as before. But I cannot find the "fix" constraint. Is it just me being blind or is this a real issue?
+1,000,000 on this!
This is a real problem that needs to get fixed ASAP! (Or sooner 😉
JWhitten
Phil.E
Thanks for reporting this. We're taking care of it. Sorry for any inconvenience.
Phil Eichmiller
Software Engineer
Quality Assurance
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
TheCADWhisperer
@Phil.E
Can you post screenshot of "New Interface"?
I reset every Default I can find in Toolbars, Panels and Preferences - restarted Fusion and all looks the same to me?
OK, I found it - in Preferences>Preview Functionality.
Thanks!
BTW, I found out that the 'Fixed' constraint is still available in the right-click pop-up menu.
John
HughesTooling
Don't know if anyone is looking at the preview forum but I reported this and the curvature constraint is missing too.
Mark
Mark Hughes
Owner, Hughes Tooling
Also, another thing I noticed was that when you isolate a part in an assembly you don't get the Unisolate command anymore. So you have to go to the assembly parent and hit unisolate all.
BTW, right-click menu workaround was cool. Thanks
