Fillet Bug
Fillet Bug
JonathanB3
Message 1 of 8
Fillet Bug
JonathanB3
I want to fillet all corners and have to fillet the backside seperate, but at one corner the fillet some times changes after I klick on finish. Can anyone help me?
Here my 3D moddel:
https://a360.co/3yDozYY
Here the Screencast (idk. why, but I cant attach it direct to this forum):
https://autode.sk/3bQO6nI
Replies (7)
Message 2 of 8
tallisb
Hello Jonathan-
I wasn't able to recreate the issue you showed.  The only thing I can think of is maybe when you are picking one of the variable blend points, it isn't catching to the exact start/end of the edge.
I created a video showing my process and that it works.
https://autode.sk/3bSVyio
Brad
Brad Tallis
Fusion 360 Technical Specialist
Message 3 of 8
JonathanB3
Hello Brad,
Thank you for your response. Just for recreational purposes, you took another point for the fillet.
I tryed it out myself and it works if I use another green snaping point, but if you use the point at the corner of the 10mm fillet then I am still able to recreate this issue. If I use another point, what would have been my next attempt, then you are not able to recreate this issue.
I have uploaded another Screencast (https://autode.sk/3uqjGzh) to show the difference.
I can recreate the issue, that my fillet jumps to another pattern if I click on finish if I set the middle fillet point on 0.905.
Message 4 of 8
JonathanB3
I will just use another point for my middle fillet marker to avoid this problem, but maybe check the .905 posittion again.
Maybe it is just a hardware related bug on my end, but who knows.
Message 5 of 8
JonathanB3
So I tryed the workaround, and it worked.
But now my save is corupt and I think it is related to this fillet..
I opened another forum entry for this.
Here the link to my corupt file post: (https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10345396)
Message 6 of 8
JonathanB3
Short update:
I created a new model looking like this one and if I create the fillet on this one edge wit the middle point at the 10mm fillet snaping point the pattern changes as I click on finish.
Message 7 of 8
JonathanB3
Here is the new version of my model with the same issue.
Message 8 of 8
JonathanB3
Hello @tallisb,
can you maybe try this again with setting the middle point to the 10mm fillet, as I exlained earlyer in this post?
In my oppinion it is driectly linked to the corrupt file after saving problem wich I explained here: https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10350421#M124154
Greetings, Jonathan
