Extending the coil
Extending the coil
nisarg.dave
Extending the coil
nisarg.dave
Hello, in attached pic1, I want to axially increase the length of the coils, I tried sectioning it and trying to pull, but fusion is not allowing me to do so. Can you suggest a solution? Thanks.11.png22.png
TheCADWhisperer
Technique 1 - edit the parameters.
Technique 2 - Split, Move, Press/Pull, Combine.
nisarg.dave
I have tried that but it didn't work. I want to increase the length of the coils from the mid-section, neither from the top-end nor from the bottom, without making a new model.
Please find the .f3d model attached.
TheCADWhisperer
Is there a logical reason that you did not use a Circular Pattern?
nisarg.dave
I have not selected a circular pattern for coils, in order to achieve the high fill factor. Thanks.
