How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
When I have, lets say "square" PCB and I exporting it to Fusion 360 via Eagle Sync I am getting correct representation of PCB like on the picture below.
But, when I am changing to the shape I required like this
I am getting storage representation where copper layer goes outside of the boards border.
I do not know is it a bug or something, I tried to create the board in Fusion it self first and then Sync from Eagle and bare Sync from Eagle with generating a new drawing automatically. The results are the same.
Is there any solution or fix?
Hi @ArttuTuomi,
Thank you for posting and Welcome to the community!
I am sorry to hear the trouble about this. Can you please take a closer look at this behavior on my system?
If it is fine with you, please share a public link to this model by posting the link, see this link for how to share a design, in this thread or sending to me via PM?
If you have any questions or concerns, please let me know.
Thank you.
Hi @ArttuTuomi,
Thank you for sharing the design.
I will take a look into this and get back here once I have something to share!
Thanks.
It is been a while...
I do not know if this will help, I am using Mac OS versions for both Eagle and Fusion 360.
Regards, Artem
Hi @ArttuTuomi,
I apologize for my delay in replying to you - I was out of office last week.
As I created a simple board and tested with EAGLE on my end, I was able to recreate this issue. I've logged a bug (internal ID: FUS-39942) with our development team to investigate this issue.
I will keep this thread updated once I have more information to share about this. Again thank you for your patience.
Thanks.
It is fine, @saito.kh!
I found a way around with using just "Line" tool in Eagle, with a "Curve" property set to 0 for those lines. It works fine if the PCB is a circle made with "Circle" tool. The rule is just to avoid "Arc" tool, it is (I think) creating this problem.
You can submit this too.
Regards, Artem
Hi @ArttuTuomi,
Thank you for the update!
I will report it to the development team as well. I apologize for any inconveniences this may cause you - we appreciate you bringing this to our attention!
I also found that it works once a circle made in Fusion was pulled and pushed by Eagle. Then I would be able to edit the shape of PCB.
Thanks.
How to buy
Type a product name
