Export stl from Fusion 360
I'm trying to export an stl from Fusion 360, but when I open the 3d model on Cura it appears  with missing pieces. How can I get a good .stl file from my project? Thank you.
MoshiurRashid
This file contains a lot of mesh, surface and t spline bodies. Most of them are faulty, I mean, self intersecting.
I guess you 3d scanned it and mesh files are from 3d scanner. Well, if you try again to 3d scan well I can modify the mesh for you in the meshmixer.
But, for this file, there are many open and intersecting faces that requires to be repaired.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
I downloaded a 3D scan of a face and tried to create a mask on the face, so I can't make any 3D scan. Can you help me create a good stl of only the Form type mask? I would really appreciate it.
jeff_strater
You cannot convert a T-Spline body (Form) directly to STL.  You must first convert them to BRep bodies:
When I tried to convert them to BRep, at least one had an error that will have to be corrected to continue:
finally, you have 4 separate T-Spline bodies in this design:
They will have to be combined into a single body to export to STL.  Once you get these 4 converted to solids, use Combine to join them together into a single body.
Jeff Strater
Engineering Director
