Error When Using the Loft Tool: Rail is not Smooth
When I select the profiles everything seems fine, but I get an error when I select the rail. stating that the "Rail is not Smooth". I carefully ensured it intersected with the profiles and it's just a simple Fit Point Spline. What am I doing wrong?
jeff_strater
it would be helpful to have the model.  The red dot is showing where it thinks the discontinuity is.  Which is odd, because that point is on a profile, not the rail.  The dialog shows chaining is disabled, otherwise it may pick up connected curves as part of the rail.  Will need to look at the model to tell for certain.
Jeff Strater
Engineering Director
Attached.
TheCADWhisperer
Sketch1 - nothing on that sketch?
Sketch2 - nothing on that sketch?
Sketch3-7 - nothing on those sketches?
Sketch11 - nothing on that sketch?
Sketch12 - nothing on that sketch?
Sketch15 - nothing on that sketch?
No dimensions on Sketch8?
No dimensions on Sketch9?
Sketch10 is "sick" (unresolved issue highlighted in the Timeline).
No dimensions?
Sketch13 is "sick" (unresolved issue highlighted in the Timeline).
No dimensions?
Sketch14 - no dimensions?
I'll be back in a few minutes with my file...
TheCADWhisperer
Note that my sketches have dimensions - so I know how big and where everything is in space.
Notice that there are no blue curves or white dots.
jeff_strater
definitely pay attention to what @TheCADWhisperer says, and look at his design.  However, I think there is still a bug here - at the very least it is a misleading error message - nothing is wrong with your rail curve, and I think that error is inappropriate to the failure.  I've created FUS-77074 to look into that.  Attached is a simplified version of the design which does show this problem.
Jeff Strater
keqingsong
benjamin.leedyMVWKP we have resolved this issue in our latest product update that we just released (V.2.0.9849).
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
