Message 1 of 13
Error code when posting to Carbide 3d Nomad
- Mute
- Permalink
- Report
Recently I've been generating a lot of toolpaths from complex vector geometries imported into fusion 360 from vector image programs like inkscape/illustrator. Fusion posts the code no problem, but every once in a while I get an error:
"Error (5): GRBL Error: The motion command has an invalid target. G2, G3, and G38.2 generates this error, if the arc is impossible to generate of if the probe target is the current position."
Why would fusion program a toolpath arc that is impossible to generate?!?! Turning off "smoothing" and decreasing the spline fidelity tolerance seems to help a bit, but not entirely.
What's going on here? How can I fix this?
Thanks!
