Error: C math library: argument domain error
daniel.ashbrook
daniel.ashbrook
I'm trying to make a sweep along a 3D path. It was working fine until I modified the path; now when I try to either update the existing sweep or make a new one I get "Error: C math library: argument domain error". F3D file attached.
jeff_strater
thanks for adding the model.  I can reproduce this error, and we will look into it.
[edit] filed as FUS-43147
Jeff
Jeff Strater
Engineering Director
I get the same error. Was this solved?
I created a circle and 3D sketch path to sweep (lines and fillets), both on sketch 2. It worked. I even mirrored it, but I could not combine-join the swept body.
I could not create a body so I looked at the sketch for errors and discovered that the circle profile was not on the sketch plane. I deleted the circle and sketched another. This circle gave a boolean error and I could not get the path to sweep so I sketched a circle at the opposite end of the path and tried to sweep that instead (same sweep). This gave me the domain error.
