Edit Joint crashes Fusion
andy.c
andy.c
When I attempt to edit a joint Fusion crashes. In the screen cast below I select a Planar joint to edit. When the Edit Joint dialog box opens two things are immediately wrong. The joint is shown as a Rigid Joint and the another box opens that says "A joint already exists between the selected components. Do you want to continue?" If I say no, Fusion crashes. If I select Yes the window appears around six times then Fusion crashes. This has been going on for days now.
jhackney1972
You Screencast did not get attached.  You also should attach your model so users can help you out directly.
John Hackney, Retired
sunil.v.b
Hi @andy.c We are sorry for the inconvenience caused. We are aware of this bug and we are actively working on a fix for this. It will help if you can share the data and a screencast with us, which can help us verify and valdiate our fix. This is the internal ticket logged FUS-72241 for this issue .
Sunil
Fusion Development Team
sunil.v.b
Hi @andy.c This issue is fixed in latest update. Please let us know if are still seeing any issues with Edit Joint.
Sunil
Fusion Development team
