Drawing dimension text height incorrect
Message 1 of 10
Drawings with limit dimensions are displaying half size compared to single value dimensions. This needs sorting as is it quite confusing and untidy.
Replies (9)
Message 2 of 10
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
I tested this and can't seem to reproduce it. I think we need @TimeraAutodesk to take a look.
Ryan Bales
Fusion 360 Product Support
Message 3 of 10
Hi Ryan,
Just to advise, I've just tested the issue again on a new drawing and the
issue still exists. Set the tolerance type to limit and the result is text
of reduced size.
Andy
[image: new drg.jpg]
Message 4 of 10
ryan.bales
Autodesk Support
Autodesk Support
I'm just not seeing it, but maybe i'm missing something:
Ryan Bales
Message 5 of 10
HughesTooling
The problem only shows with ISO drawings, ASME the text stays the same size. Don't know if the standard is different for ISO.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 10
ryan.bales
Autodesk Support
Autodesk Support
Thanks @HughesTooling, guess its good you are using ISO style!
I see it now and i'm hoping Timera can chime in on this when she gets to it.
Ryan Bales
Message 7 of 10
HughesTooling
I probably should be using the ISO style but there are a few things I don't like about it so use ASME. Wish there were overrides for some things, like I don't know anyone that uses first angle projection. I know it's probably the standard for iso but I think a lot of people override this setting.
Mark
Mark Hughes
Message 8 of 10
Hi Fusion Team,
Any feedback on when this issue will be resolved as it does/will stop ISO drawings being created with clarity?
Andy Barnes
Message 9 of 10
Hi Ryan,
Did this issue ever get looked at?
Andy Barnes
Message 10 of 10
I've just come back to Fusion 360 after a couple of years and I see that this ISO dimension limit text size has still not been addressed! Surely, this is a quick fix?
Andy B
