Dimensions Font and grid reference numbers are very large
rickmyenAM29R
rickmyenAM29R
I'm coming from tinkercad and have not run into this before.  When creating a sketch, my dimension font is huge... I can turn off the grid reference numbers which are the same size, but the dimension font is the one I would like to change.
Would anyone here be able to assist me in correcting the number appearance?  I'm running fusion 360 ver 2.0.9719 on a retina macbook pro.
Any help at all would be greatly appreciated.
Phil.E
This looks like a bug. There is no setting to correct this.
Have you tried restarting your computer yet?
Do you have an external monitor, or is this on your MBP screen?
Have you tried changing screen resolution to see if it has an effect?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
rickmyenAM29R
Yes I have restarted the laptop and tried it with and without an external monitor. Changing screen resolutions do not help either.
Thank-you for you reply
Phil.E
It looks like a font problem. At this point it's worthwhile to try a clean install.
Please let me know if that helps.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
