Can Fusion dimension and display six ft four and a half inches yet? Like 6' 4-1/2" or 6ft 4-1/2in, etc. Or do I have to manually force this on each dimension. Any input is greatly appreciated.
Matt
I am assuming your are talking about entering dimensions in the model sketch environment. If so, you can enter 6'4 1/2" and it will display as that same format if you have your Preferences set correctly.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
