Design window stuck after sleep
roman_Sholiak
Message 1 of 11
roman_Sholiak
Hi
Did anyone facing main window stuck after PC wake-up from sleep ?
  • Bugs
Replies (10)
Message 2 of 11
roman_Sholiak
Working with external monitor from laptop ( using Intel HD grafics 520 ) and when turn-off / on monitor same stuck of the window happend .
Did anyone has any ideas ?
Video driver updated to latest version .
Message 3 of 11
g.buser
I have a similar problem since a few days, after sleep, no model is shown anymore and I have to restart fusion to get it back.
Message 4 of 11
roman_Sholiak
Fusion reboot help`s - but when you do it 20 times per day or more it`s not a work ...
Message 5 of 11
jimnel
Yes, I have the same problem.  It started having this symptom recently.  Frustrating
Message 6 of 11
biasedlogic
Another user with this problem.
Fusion on 2.0.9642
Laptop with Intel built in GPU
Problem appeared after last update - not necessarily the very latest version, but definitely a release from within the past month or so. I was working on last version of Fusion and had no issues, at some point Fusion reported that update is ready and to restart it and the issue appeared. No system change, not even reboot in between.
Message 7 of 11
devau.remi
Observer
Observer
I have the same issue.
Laptop with intel graphics. I tried to update graphics drivers with previous version, same issue.
Hope Fusion team will hear us!
Regards;
Message 8 of 11
roman_Sholiak
Uninstall Fusion with Fusion cleaner and re-intall again - result is the same .
Any ideas ?
Message 9 of 11
biasedlogic
There's a workaround with an environment variable forcing OpenGL, it works
on my machine (screen stopped freezing), but - maybe unrelated - since I
applied it my Fusion started crashing every now and then, which previously
was a non issue. The workaround is described somewhere here on the forum, I
believe it was even linked in this thread.
Best regards
Marek
Message 10 of 11
roman_Sholiak
Fusion update fix the issue - V.2.0.9719
https://www.autodesk.com/products/fusion-360/blog/february-2021-product-update-whats-new/
Great Thanks !
Message 11 of 11
Laptop with intel graphics. I tried to update graphics drivers with previous version, same issue and lost my bassinet.
Regards;
Recently, I have faced the same issue.
