Default sketch fillet radius too big for small elements
In a sketch, if any of the two lines (or arcs) meeting in a point (confirmed intersection by trimming) is shorter than the initial suggestion for a fillet Fusion 360 will only say that it can not create the fillet, no explanation why.
Try by making two elements and adjusting the lengths. Adjusting after fillet creation keeps the fillet, Adjusting the fillet to desired size works. But if the initial elements will not touch the resulting initial (suggested?) fillet radius it will not work.
Is there a setting to determine initial fillet size? When doing it in 3D it starts a 0, why not in sketch? Mine is set at 18 mm which is seems very arbitrary.
