Curvature Map Analysis Scale Bug
Here's a small bug I discovered: if you go into Curvature Map Analysis the scale input box will only show scales up to 9.999, if you go to 10.000 the 1 gets cut off from the input box. This however becomes more apparent if after you ok the parameters and go back to edit them. Only the last digit shows with the subscript mm. Here is a screenshot: Screenshot 2017-10-19 18.10.49.png
paul.clauss
Hi @Anonymous
Thanks for posting! I received the same behavior on my end and have logged a ticket with our development team (FUS-36553) to ensure this is improved in a future update to Fusion. We appreciate you bringing this to our attention - feel free to reach out if you have any questions!
Paul Clauss
Product Support Specialist
