BUG. Sweep with twist.
HughesTooling
Consultant Consultant
HughesTooling
The twist option in the sweep command does not save a calculation, it converts it to a number. In the attached file from the parameter manager you can see I've set the twist to 360*Turns, if you edit the sweep feature it's converted to 1800°
Mark
Mark Hughes
Owner, Hughes Tooling
rishabh.bisht
Hi Mark,
Thanks for sharing this!
That definitely is a bug on our end. I can reproduce it for both Taper Angle and Twist angle.
I have logged a ticket for further investigation. (internal reference FUS-44323).
We'll try to get this fixed soon.
Rishabh Bisht
Product Owner
rishabh.bisht
Hi @HughesTooling, this issue should be fixed with the January 2019 release. Please let us know if you still encounter this issue.
Thanks!
Rishabh Bisht
Product Owner
