I believe I've seen this reported before. In this case I created both models.
I can share the design with an AD employee.
As can be seen in the screencast, when I edit the joint that attaches the leg to the in the original conveyor it behaves normally.
However, when I insert that design into another one and edit it, it flips 90 degrees and when moving the handle arrow it move in a direction 90 degrees rotated from the direction of the arrow.
I've not been able to reproduce this in a quick test with an empty design.
Hi Peter,
Thank you for reporting the issue! Could you share a public link to the design via private message so we can investigate?
Thank you! I couldn't find an existing ticket for this issue so I logged it as a new one (FUS-48056).
Thank you for bringing this to our attention!
I am not going to repots as a separate bug, because I think the root cause for this is the same.
I created a new assembly Tape Rolls and created a sketch for a component on top off the conveyor belt surface.
remember, that conveyor was inserted and then the link broken.
I then created another component and pulled the sketch into it. then I extruded the sketch to end up with a sketch and cylinder body in that component.
When I pattern that component I see this:
