BUG: Inpropiate joint min and max limit behavior
01:16 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here is my design:
Version 1
In assembly : "Zlozenie napedu wysokosci miedzy pasami" there is joint named "HGW20HC1 slide".
I drive the joint to position 68 and then to position 220. I set up "Edit joints limit" to minimum 68 and maximum 220.
Try to move the HGW20HC_1_R_400_Z0_H_ZZX component and you will notice that "Drive position" is different from limited position and there is no possibility to set up proper position by fiddling with min and max limits.
I fight with this for few hours. Gave up.
Hopefully you can solve this.
Krzysztof
