Hey support peeps 🙂
I was playing around with adding joints to a project the other day, as an exercise in learning as much as adding a feature, and I found that everytime I open the joint type dropdown, a new "Angle" item appears (see screencast). I've closed and reopened the file multiple times to test it's reproducibility, and ensure I'm on the latest version.
Screencast pending, so cannot post to ticket form, so posting here: https://autode.sk/3eQPOEF
File in question can be found here: https://a360.co/30vcxRv
Steps to reproduce:
Thanks. This isn't something that holds me up, just an oddity.
Paul
Confirmed! @jeff_strater you may want to look at this issue.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
wow. That one wins "entertaining bug of the month". I had not seen that one before. That must be a new one, or we would have heard about it before. I created Fusion bug FUS-69349 to track it. Thanks for taking the time to record a screencast and post it.
