Appearance in Fusion 360 Drawing Sheet Issue
krishna.pula
Message 1 of 8
krishna.pula
Hi, This issue is not resolved yet. There are a lot of drawings that need updating. The components must be linked to the drawing file, however, if they are applied to an old design file. They do not appear in the same order as other components. Please find a screenshot below showing this issue.
Drawing Sheet Screenshot below
Replies (7)
Message 2 of 8
ClintBrown3D
Hi @krishna.pula
I’m sorry to hear that you are having trouble. Please can you share the drawing with me, so that I can get the team to have a look at this for you.
You can share a link to the drawing file here, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com.
cc: @Pramod.kadam @rohit.bapat
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 3 of 8
krishna.pula
Hi @ClintBrown3D ,
Please find below the screenshot of what I am facing in the drawing file that is attached in the F3z attachment. In this case, I have to delete the view and reposition it again. I have to mention Bom and Dimension once more.
Message 4 of 8
ClintBrown3D
Hi @krishna.pula
Thank you for sharing the files with me. I have shared them with the team.
We'll let you know what we find. In the meantime, please make sure that all updates to Fusion are installed.
cc: @rohit.bapat @Pramod.kadam
Clint Brown
Message 5 of 8
ClintBrown3D
Hi @krishna.pula  
I just tested your dataset. Have a look at the animated GIF below, if you toggle between shaded and non-shaded views, the issue is resolved.
Clint Brown
Message 6 of 8
krishna.pula
Hi @ClintBrown3D ,
Previously I've received this solution, but try copying and pasting one drawer, shelf, or any other component from your side into my design. After linking to the drawing, you suggested a solution that does not work.
Message 7 of 8
ClintBrown3D
Hi @krishna.pula
I've opened your model, added another drawer and updated the drawing. Everything seems to be working fine on my end, have a look at this video showing the workflow: https://www.youtube.com/watch?v=37kPZvOJmuc
Please can you share something similar, so that I can see the issue first hand.
Clint Brown
Message 8 of 8
krishna.pula
Hi @ClintBrown3D
The attached video shows the issue that I had on my computer. Likewise, I have shared one more file with you. Install it as I did in the video.
