Angle hole moves after clicking OK
stew985
stew985
Hi, I have a 3d body. For reference is a rock drill cone, google "rock drill cone". I am putting holes in it at different levels. When I get to the holes on the cone that are on an angle and I use"make hole" it works. I click on the hole and the click the bottom plane and I enter the height and it looks OK. My problem is when I click OK the hole position moves up if I dimension it from the bottom and down if I dimension it from the top. I can't figure out why it's doing that.
Replies (7)
aaronkcap
Can you please post the file. One work around could be to do a tangent plane and put in the circle place you want the hole or put a point if you want to use the hole tool
pawel.potyrala
Autodesk Support
Autodesk Support
Hello @stew985,
Welcome to Fusion 360 community forum. Thanks for posting!
As I understand, you are trying to create holes in the sloped face of the body and you want to put them in the desired position.
You chose the sloped face of the body as the face to create the hole in. In the next step, you added the edge of the bottom (or the top), horizontally oriented face of the body as the reference (see the attached screenshot). By doing that, you were able to define the distance between the center point of the hole on the sloped face and the referenced edge.
As a result of changing this distance, the location of the hole changes. This way you can put the hole in the desired position in reference to the edge of the top or the bottom face.
Should you want to position the hole randomly, you can move it by dragging the center point. An alternative might be creating a sketch on a tangent plane that @aaronkcap mentioned.
You can find a description of the Hole dialog box here.
If this answers your question, please let us know by marking this post as a solution. Enjoy using Fusion 360!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
stew985
Yes this is what I did but the issue is that when I click OK it moves. I have attached 3 more screen shots in sequence.
pawel.potyrala
Autodesk Support
Autodesk Support
Hello @stew985,
Thanks a lot for the update and explanation!
Does the issue occur while referencing the two specific planes that you mentioned or every single time you define a hole and use a reference object?
Would you mind sharing your design with me, so that I can reproduce the problem?
Thanks a lot!
Paweł Potyrała
stephen
Here is the file
pawel.potyrala
Autodesk Support
Autodesk Support
Hello @stephen,
sorry for getting back to you so late.
I was able to reproduce the error in your design, as well as in some other simple designs I created.
Positioning the hole with a reference seems to be working correctly if the plane one puts the hole in is perpendicular to the referenced plane, but the hole is indeed relocated for any other angle after confirming the distance.
I am going to log it in with our development team.
For now, you can consider using the workaround @aaronkcap provided to achieve a precise geometry. Should you need any help with the workaround, let me know.
Best regards,
Paweł Potyrała
stephen
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
